Test generation with inputs, outputs and repetitive quiescence. Software -Concepts and Tools, pp.103-120, 1996. ,
Refusal testing for classes of transition systems with inputs and outputs, IFIP Conference Proceedings, vol.107, pp.23-38, 1997. ,
DOI : 10.1007/978-0-387-35271-8_2
Test de syst??mes r??actifs non r??ceptifs, Journal Europ??en des Syst??mes Automatis??s, vol.39, issue.1-3, pp.255-270, 2005. ,
DOI : 10.3166/jesa.39.255-270
Test Purpose Concretization through Symbolic Action Refinement, In: TestCom. LNCS, vol.17, issue.3, pp.184-199, 2008. ,
DOI : 10.1007/11430230_7
Symbolic Model-based Test Selection, Electronic Notes in Theoretical Computer Science, vol.240, pp.167-184, 2009. ,
DOI : 10.1016/j.entcs.2009.05.051
Conformance testing for real-time systems, Formal Methods in System Design, vol.10, issue.1???2, pp.238-304, 2009. ,
DOI : 10.1007/s10703-009-0065-1
Testing Real-Time Systems Using UPPAAL, LNCS, vol.4949, pp.77-117, 2008. ,
DOI : 10.1007/978-3-540-78917-8_3
Implementation Relations for the Distributed Test Architecture, In: TestCom. LNCS, vol.29, issue.7, pp.200-215, 2008. ,
DOI : 10.1007/978-3-540-73066-8_12
Algebraic Theory of Processes, 1988. ,
From testing theory to test driver implementation, FME, pp.538-556, 1996. ,
DOI : 10.1007/3-540-60973-3_106
Concurrent and Real Time Systems: The CSP Approach, 1999. ,
A technique of state space search based on unfolding, Formal Methods in System Design, vol.22, issue.12, pp.45-65, 1995. ,
DOI : 10.1007/BF01384314
An improvement of McMillan's unfolding algorithm, LNCS, vol.1055, pp.87-106, 1996. ,
DOI : 10.1007/3-540-61042-1_40
Synthesis of distributed testers from true-concurrency models of reactive systems, Information and Software Technology, vol.45, issue.12, pp.805-814, 2003. ,
DOI : 10.1016/S0950-5849(03)00061-2
URL : https://hal.archives-ouvertes.fr/inria-00072021
Specification-based testing of concurrent systems, Conf. Proc., Chapman & Hall, pp.7-22, 1998. ,
DOI : 10.1007/978-0-387-35271-8_1
Conformance Relations for Labeled Event Structures, LNCS, vol.7305, pp.83-98, 2012. ,
DOI : 10.1007/978-3-642-30473-6_8
Unfolding-Based Test Selection for Concurrent Conformance, In: ICTSS. LNCS, vol.8254, pp.98-113, 2013. ,
DOI : 10.1007/978-3-642-41707-8_7
Model based testing for concurrent systems with labeled event structures, 2012. ,
Local Testing of Message Sequence Charts Is Difficult, In: FCT. LNCS, vol.4639, pp.76-87, 2007. ,
DOI : 10.1007/978-3-540-74240-1_8
Global and local testing from Message Sequence Charts, Proceedings of the 27th Annual ACM Symposium on Applied Computing, SAC '12, pp.1332-1338, 2012. ,
DOI : 10.1145/2245276.2231987
Towards Automatic Distribution of Testers for Distributed Conformance Testing, Conference Proceedings., Kluwer, pp.353-368, 1998. ,
DOI : 10.1007/978-0-387-35394-4_22
Tagging Make Local Testing of Message-Passing Systems Feasible, 2008 Sixth IEEE International Conference on Software Engineering and Formal Methods, pp.171-180, 2008. ,
DOI : 10.1109/SEFM.2008.33
Using Time to Add Order to Distributed Testing, In: FM. LNCS, vol.7436, pp.232-246, 2012. ,
DOI : 10.1007/978-3-642-32759-9_20
Virtual time and global states of distributed systems, In: Parallel and Distributed Algorithms, pp.215-226, 1989. ,
Timestamps in Message-Passing Systems that Preserve the Partial Ordering, 11th Australian Computer Science Conference, pp.55-66, 1988. ,
Quiescence, Fairness, Testing, and the Notion of Implementation, Information and Computation, vol.138, issue.2, pp.194-210, 1997. ,
DOI : 10.1006/inco.1997.2652
Petri nets, morphisms and compositionality, pp.453-477, 1985. ,
DOI : 10.1007/BFb0016226
On distributability of Petri nets -(extended abstract), FoSSaCS. LNCS, vol.7213, pp.331-345, 2012. ,
Petri nets, event structures and domains, part I, Theoretical Computer Science, vol.13, issue.1, pp.85-108, 1981. ,
DOI : 10.1016/0304-3975(81)90112-2
URL : http://doi.org/10.1016/0304-3975(81)90112-2
