Error Estimates for Second Order Hamilton-Jacobi-Bellman Equations. Approximation of Probabilistic Reachable Sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series A Année : 2015
Mohamed Assellaou
  • Fonction : Auteur
  • PersonId : 956835
Olivier Bokanowski
Hasnaa Zidani
This work deals with numerical approximations of unbounded and discontinuous value functions associated to some stochastic control problems. We derive error estimates for monotone schemes based on a Semi-Lagrangian method (or more generally in the form of a Markov chain approximation). A motivation of this study consists in approximating chance-constrained reachability sets. The latters will be characterized as level sets of discontinuous value functions associated to adequate stochastic control problems. A precise analysis of the level-set approach is carried out and some numerical simulations are given to illustrate the approach.
Assellaou_Bokanowski_Zidani_submitted.pdf (462.27 Ko) Télécharger le fichier
hal-00998371 , version 1 (02-06-2014)
hal-00998371 , version 2 (27-07-2015)
Mohamed Assellaou, Olivier Bokanowski, Hasnaa Zidani. Error Estimates for Second Order Hamilton-Jacobi-Bellman Equations. Approximation of Probabilistic Reachable Sets. Discrete and Continuous Dynamical Systems - Series A, 2015, 35 (9), pp.3933 - 3964. ⟨10.3934/dcds.2015.35.3933⟩. ⟨hal-00998371v1⟩
Collections
PARISTECH
834 Consultations
394 Téléchargements
