New interface
Conference papers
Rate Distortion Optimized Tone Curve for High Dynamic Range Compression
Mikael Le Pendu 1, 2 Christine Guillemot 1 Dominique Thoreau 2
1 Sirocco - Analysis representation, compression and communication of visual data
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : In this paper, we define a reversible tone mapping-operator (TMO) for efficient compression of High Dynamic Range (HDR) images using a Low Dynamic Range (LDR) encoder. In our compression scheme, the HDR image is tone mapped and encoded. The inverse tone curve is also encoded, so that the decoder can reconstruct the HDR image from the LDR version. Based on a statistical model of the encoder error and assumptions on the rate of the encoded LDR image, we find a closed form solution for the optimal tone curve with respect to the rate and the mean square error (MSE) of the reconstructed HDR image. It is shown that the proposed method gives superior compression performance compared to existing tone mapping operators.
Complete list of metadata
https://hal.inria.fr/hal-00998480
Contributor : Mikael Le Pendu Connect in order to contact the contributor
Submitted on : Monday, June 2, 2014 - 11:06:56 AM
Last modification on : Wednesday, February 2, 2022 - 3:50:52 PM
Identifiers
  • HAL Id : hal-00998480, version 1
Citation
Mikael Le Pendu, Christine Guillemot, Dominique Thoreau. Rate Distortion Optimized Tone Curve for High Dynamic Range Compression. EUSIPCO - 22nd European Signal Processing Conference, Sep 2014, Lisbon, Portugal. ⟨hal-00998480⟩
Share
Metrics
Record views
300
