Network Coding Taxonomy
This document summarizes a recommended terminology for Network Coding concepts and constructs. It provides a comprehensive set of terms with unique names in order to avoid ambiguities in future Network Coding IRTF and IETF documents. This document is intended to be in- line with the terminology used by the RFCs produced by the Reliable Multicast Transport (RMT) and FEC Framework (FECFRAME) IETF working groups.
draft-firoiu-nwcrg-network-coding-taxonomy-01.pdf (32.68 Ko)
Télécharger le fichier
