Network Coding Taxonomy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2014
This document summarizes a recommended terminology for Network Coding concepts and constructs. It provides a comprehensive set of terms with unique names in order to avoid ambiguities in future Network Coding IRTF and IETF documents. This document is intended to be in- line with the terminology used by the RFCs produced by the Reliable Multicast Transport (RMT) and FEC Framework (FECFRAME) IETF working groups.
draft-irtf-nwcrg-network-coding-taxonomy-00 (1).pdf (31.23 Ko) Télécharger le fichier
hal-00998506 , version 1 (02-06-2014)
hal-00998506 , version 2 (02-12-2014)
hal-00998506 , version 3 (07-11-2017)
hal-00998506 , version 4 (12-11-2018)
  • HAL Id : hal-00998506 , version 2
Victor Firoiu, Brian Adamson, Vincent Roca, Cédric Adjih, Josu Bilbao, et al.. Network Coding Taxonomy. 2014. ⟨hal-00998506v2⟩
885 Consultations
511 Téléchargements
