Optimal spilling for cisc machines with few registers, Proceedings of the ACM SIGPLAN 2001 conference on Programming language design and implementation, pp.243-253, 2000. ,
Rematerialization-based register allocation through reverse computing, Proceedings of the 8th ACM International Conference on Computing Frontiers, CF '11, p.24, 2011. ,
DOI : 10.1145/2016604.2016632
Global constraint catalog, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00485396
Optimal Design of Truss Structures by Logic-Based Branch and Cut, Operations Research, vol.49, issue.1, pp.42-51, 2001. ,
DOI : 10.1287/opre.49.1.42.11196
On the complexity of spill everywhere under ssa form, LCTES'07, pp.103-112, 2007. ,
URL : https://hal.archives-ouvertes.fr/ensl-00180322
Rematerialization, ACM SIGPLAN Notices, vol.27, issue.7, pp.311-321, 1992. ,
DOI : 10.1145/143103.143143
Improving register allocation for subscripted variables, Proceedings of the ACM SIGPLAN 1990 Conference on Programming Language Design and Implementation, PLDI '90, pp.53-65, 1990. ,
Register allocation via graph coloring, Journal of Computer Languages, vol.6, pp.45-57, 1981. ,
Analysis of pointers and structures, Proceedings of the ACM SIGPLAN 1990 Conference on Programming Language Design and Implementation, PLDI '90, pp.296-310, 1990. ,
Register allocation by priority-based coloring, ACM SIGPLAN Notices, vol.39, issue.4, pp.91-103, 2004. ,
DOI : 10.1145/989393.989406
Studying optimal spilling in the light of ssa Architectures and Synthesis for Embedded Systems, Proceedings of the 14th International Conference on Compilers, pp.25-34, 2011. ,
Application of CLP to instruction modulo scheduling for VLIW processors ,
Register pipelining: An integrated approach to register allocation for scalar and subscripted variables, Proceedings of the 4th International Conference on Compiler Construction, CC '92, pp.192-206, 1992. ,
DOI : 10.1007/3-540-55984-1_18
On Local Register Allocation, Journal of Algorithms, vol.37, issue.1, pp.37-65, 2000. ,
DOI : 10.1006/jagm.2000.1095
Compiler optimizations for scalable parallel systems. chapter Array Dataflow Analysis, pp.173-219, 2001. ,
Iterated register coalescing, ACM Transactions on Programming Languages and Systems, vol.18, issue.3, pp.300-324, 1996. ,
DOI : 10.1145/229542.229546
Register Allocation for Programs in SSA-Form, Compiler Construction, pp.247-262, 2006. ,
DOI : 10.1007/11688839_20
Algorithms for Hybrid MILP/CP Models for a Class of Optimization Problems, INFORMS Journal on Computing, vol.13, issue.4, pp.258-276, 2001. ,
DOI : 10.1287/ijoc.13.4.258.9733
Constraints-driven scheduling and resource assignment, ACM Transactions on Design Automation of Electronic Systems, vol.8, issue.3, pp.355-383, 2003. ,
DOI : 10.1145/785411.785416
Register promotion by sparse partial redundancy elimination of loads and stores, ACM SIGPLAN Notices, vol.33, issue.5, pp.26-37, 1998. ,
DOI : 10.1145/277652.277659
Register Pressure Guided Loop Optimization, 2007. ,
Combining register allocation and instruction scheduling. Courant Institute, 1995. ,
Linear relaxations and reduced-cost based propagation of continuous variable subscripts, CP-AI-OR'00 Workshop on Integration of AI and OR techniques in Constraint Programming for Combinatorial Optimization Problems, 2000. ,
Improved Algorithms for the Global Cardinality Constraint, Principles and Practice of Constraint Programming ? CP 2004, pp.542-556, 2004. ,
DOI : 10.1007/978-3-540-30201-8_40
Generalized arc consistency for global cardinality constraint, Proceedings of the thirteenth national conference on Artificial intelligence AAAI'96, pp.209-215, 1996. ,
A filtering algorithm for constraints of difference in csps, Proceedings of the Twelfth National Conference on Artificial Intelligence AAAI '94, pp.362-367, 1994. ,
Combined ilp and register tiling: Analytical model and optimization framework, LCPC, pp.244-258, 2005. ,
Handbook of Constraint Programming (Foundations of Artificial Intelligence), 2006. ,
Using Constraint Programming and Local Search Methods to Solve Vehicle Routing Problems, Proceedings of the 4th International Conference on Principles and Practice of Constraint Programming, CP '98, pp.417-431, 1998. ,
DOI : 10.1007/3-540-49481-2_30
Cplan: A constraint programming approach to planning American Association for Artificial Intelligence, Proceedings of the Sixteenth National Conference on Artificial Intelligence and the Eleventh Innovative Applications of Artificial Intelligence Conference Innovative Applications of Artificial Intelligence, AAAI '99/IAAI '99, pp.585-590, 1999. ,
Inovallée 655 avenue de l'Europe Montbonnot 38334 Saint Ismier Cedex Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria, pp.249-6399 ,
