Heterogeneous Data Fusion Algorithm for Pedestrian Navigation via Foot-Mounted Inertial Measurement Unit and Complementary Filter Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Instrumentation and Measurement Année : 2015
This paper proposes a foot-mounted Zero Velocity Update (ZVU) aided Inertial Measurement Unit (IMU) filtering algorithm for pedestrian tracking in indoor environment. The algorithm outputs are the foot kinematic parameters, which include foot orientation, position, velocity, acceleration, and gait phase. The foot motion filtering algorithm incorporates methods for orientation estimation, gait detection, and position estimation. A novel Complementary Filter (CF) is introduced to better pre-process the sensor data from a foot-mounted IMU containing tri-axial angular rate sensors, accelerometers, and magnetometers and to estimate the foot orientation without resorting to GPS data. A gait detection is accomplished using a simple states detector that transitions between states based on acceleration and angular rate measurements. Once foot orientation is computed, position estimates are obtained by using integrating acceleration and velocity data, which has been corrected at step stance phase for drift using an implemented ZVU algorithm, leading to a position accuracy improvement.We illustrate our findings experimentally by using of a commercial IMU during regular human walking trials in a typical public building. Experiment results show that the positioning approach achieves approximately a position accuracy around 0.4% and improves the performance regarding recent works of literature.
Fichier non déposé
hal-00999073 , version 1 (03-06-2014)
Hassen Fourati. Heterogeneous Data Fusion Algorithm for Pedestrian Navigation via Foot-Mounted Inertial Measurement Unit and Complementary Filter Design. IEEE Transactions on Instrumentation and Measurement, 2015, 64 (1), pp.221-229. ⟨10.1109/TIM.2014.2335912⟩. ⟨hal-00999073⟩
442 Consultations
0 Téléchargements
