Radiometric CCD camera calibration and noise estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.3, pp.267-276, 1994. ,
DOI : 10.1109/34.276126
Image restoration with noise suppression using a multiresolution support, Astronomy and astrophysics, vol.112, pp.179-189, 1995. ,
Sensor Noise Modeling by Stacking Pseudo-Periodic Grid Images Affected by Vibrations, IEEE Signal Processing Letters, vol.21, issue.4, pp.432-436, 2014. ,
DOI : 10.1109/LSP.2014.2304570
URL : https://hal.archives-ouvertes.fr/hal-00955709
Producing and transferring low-spatial-frequency grids for measuring displacement fields with moiré and grid methods, Experimental Techniques, pp.23-26, 2004. ,
Photomechanics, Topics in Applied Physic 77, chapter on fringe analysis, pp.55-102, 2000. ,
Investigation of the grid method for accurate in-plane strain measurement, Measurement Science and Technology, vol.20, issue.9, p.95102, 2009. ,
DOI : 10.1088/0957-0233/20/9/095102
Additive noise effect in digital phase detection, Applied Optics, vol.36, issue.1, pp.271-276, 1997. ,
DOI : 10.1364/AO.36.000271
Towards deconvolution to enhance the grid method for in-plane strain measurement, Inverse Problems and Imaging, vol.8, issue.1, pp.259-291, 2014. ,
DOI : 10.3934/ipi.2014.8.259
URL : https://hal.archives-ouvertes.fr/hal-00749804
Using deconvolution to improve the metrological performance of the grid method, Optics and Lasers in Engineering, vol.51, issue.6, pp.716-734, 2013. ,
DOI : 10.1016/j.optlaseng.2013.01.009
Chapter 1. Basics of metrology and introduction to techniques ,
Full-field measurements and identification in solid mechanics, pp.1-29, 2012. ,
Anniversary Article: Effect of Sensor Noise on the Resolution and Spatial Resolution of Displacement and Strain Maps Estimated with the Grid Method, Strain, vol.22, issue.1, pp.1-27, 2014. ,
DOI : 10.1111/str.12070
A Wavelet Tour of Signal Processing, Third Edition: The Sparse Way, 2008. ,
Comparison of Local and Global Approaches to Digital Image Correlation, Experimental Mechanics, vol.39, issue.8, pp.1503-1519, 2012. ,
DOI : 10.1007/s11340-012-9603-7
URL : https://hal.archives-ouvertes.fr/hal-00750756
Use of rigid-body motion for the investigation and estimation of the measurement errors related to digital image correlation technique, Optics and Lasers in Engineering, vol.46, issue.2, pp.185-196, 2008. ,
DOI : 10.1016/j.optlaseng.2007.05.008
