New interface
Reports (Research report)
A combination of algebraic, geometric and numerical methods in the contrast problem by saturation in magnetic resonance imaging
Abstract : In this article, the contrast imaging problem by saturation in nuclear magnetic resonance is modeled as a Mayer problem in optimal control. The optimal solution can be found as an extremal solution of the Maximum Principle and analyzed with the recent advanced techniques of geometric optimal control. This leads to a numerical investigation based on shooting and continuation methods implemented in the HamPath software. The results are compared with a direct approach to the optimization problem and implemented within the Bocop toolbox. In complement lmi techniques are used to estimate a global optimum. It is completed with the analysis of the saturation problem of an ensemble of spin particles to deal with magnetic fields inhomogeneities.
Document type :
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-01001975
Contributor : Olivier Cots Connect in order to contact the contributor
Submitted on : Thursday, June 5, 2014 - 12:26:57 PM
Last modification on : Friday, November 25, 2022 - 10:12:06 AM
Long-term archiving on: : Friday, September 5, 2014 - 11:36:25 AM
File
art.pdf
Identifiers
  • HAL Id : hal-01001975, version 1
Citation
Bernard Bonnard, Mathieu Claeys, Olivier Cots, Alain Jacquemard, Pierre Martinon. A combination of algebraic, geometric and numerical methods in the contrast problem by saturation in magnetic resonance imaging. [Research Report] LAAS-CNRS. 2014. ⟨hal-01001975⟩
Share
Metrics
Record views
707
Files downloads
101
