New interface
Conference papers
Geometric articulatory model adapted to the production of consonants
Yves Laprie 1 Béatrice Vaxelaire 2 Martine Cadot 1
1 PAROLE - Analysis, perception and recognition of speech
Inria Nancy - Grand Est, LORIA - NLPKD - Department of Natural Language Processing & Knowledge Discovery
Abstract : This works deals with the construction of articulatory models which can be easily adapted to a new speaker and enable a better approximation of tongue contours corresponding to consonants. Data used are three corpora of X-ray films. The first corpus was used to construct an articulatory model and design an adaptation procedure. The evaluation carried out on the third corpus shows that this adaptation performs well. Geometric fitting provided by the first model was often insufficient in the region of the consonantal places of articulation of the second corpus. Tongue contours delineated from X-ray images were thus corrected by considering virtual articulatory targets and the weight of consonants was increased in the Principal Component Analysis (PCA). Furthermore, the coefficients of the linear components are not calculated by projecting contours onto the PCA base vectors, but with an optimization procedure so as to guarantee a good approximation in the constriction region of consonants.
Document type :
Conference papers
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01002125
Contributor : Yves Laprie Connect in order to contact the contributor
Submitted on : Thursday, June 5, 2014 - 4:11:22 PM
Last modification on : Saturday, June 25, 2022 - 7:40:01 PM
Long-term archiving on: : Friday, September 5, 2014 - 12:15:56 PM
File
articulatoryModel.pdf
Identifiers
  • HAL Id : hal-01002125, version 1
Citation
Yves Laprie, Béatrice Vaxelaire, Martine Cadot. Geometric articulatory model adapted to the production of consonants. 10th International Seminar on Speech Production (ISSP), May 2014, Köln, Germany. ⟨hal-01002125⟩
Share
Metrics
Record views
212
Files downloads
108
