Discovery of Probabilistic Mappings between Taxonomies: Principles and Experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we investigate a principled approach for de?ning and discovering probabilistic mappings between two taxonomies. First, we compare two ways of modeling probabilistic mappings which are compatible with the logical constraints declared in each taxonomy. Then we describe a generate and test algorithm which minimizes the number of calls to the probability estimator for determining those mappings whose probability exceeds a certain threshold. Finally, we provide an experimental analysis of this approach.
Fichier non déposé
hal-01002693 , version 1 (06-06-2014)
  • HAL Id : hal-01002693 , version 1
Remi Tournaire, Alexandre Termier, Jean-Marc Petit, Marie-Christine Rousset. Discovery of Probabilistic Mappings between Taxonomies: Principles and Experiments. Journées Bases de Données Avancées (BDA 2009), 2009, namur, Belgium, Belgium. pp.1--12. ⟨hal-01002693⟩
199 Consultations
0 Téléchargements
