Conference papers
Parallel Generic Pattern Mining
Alexandre Termier 1
Abstract : Pattern mining is the ?eld of data mining concerned with ?nding repeating patterns in data. Due to the combinatorial nature of the computations performed, it requires a lot of computation time and is therefore an important target for parallelization. In this work we show our parallelization of a generic pattern mining algorithm, and how the pattern de?nition in?ues on the parallel scalability. We also show that the main limiting factor is in most cases the memory bandwidth, and how we could overcome this limitation.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01002697
Contributor : Fabrice Jouanot Connect in order to contact the contributor
Submitted on : Friday, June 6, 2014 - 3:43:52 PM
Last modification on : Sunday, June 26, 2022 - 9:35:29 AM
Identifiers
  • HAL Id : hal-01002697, version 1
Collections
Citation
Alexandre Termier. Parallel Generic Pattern Mining. Seminar in Dagstuhl School, Parallel Data Analysis, 2013, Dagstuhl, Germany, Germany. ⟨hal-01002697⟩
Share
Metrics
Record views
60
