New interface
Conference papers
A low variance consistent test of relative dependency
Abstract : We describe a novel non-parametric statistical hypothesis test of relative dependence between a source variable and two candidate target variables. Such a test enables us to determine whether one source variable is significantly more dependent on a first target variable or a second. Dependence is measured via the Hilbert-Schmidt Independence Criterion (HSIC), resulting in a pair of empirical dependence measures (source-target 1, source-target 2). We test whether the first dependence measure is significantly larger than the second. Modeling the covariance between these HSIC statistics leads to a provably more powerful test than the construction of independent HSIC statistics by sub-sampling. The resulting test is consistent and unbiased, and (being based on U-statistics) has favorable convergence properties. The test can be computed in quadratic time, matching the computational complexity of standard empirical HSIC estimators. The effectiveness of the test is demonstrated on several real-world problems: we identify language groups from a multilingual corpus, and we prove that tumor location is more dependent on gene expression than chromosomal imbalances. Source code is available for download at https://github.com/wbounliphone/reldep.
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/hal-01005828
Contributor : Matthew Blaschko Connect in order to contact the contributor
Submitted on : Wednesday, May 20, 2015 - 11:31:01 PM
Last modification on : Saturday, June 25, 2022 - 10:16:29 PM
Long-term archiving on: : Thursday, April 20, 2017 - 5:46:45 AM
relative_dependency.pdf
Identifiers
  • HAL Id : hal-01005828, version 4
  • ARXIV : 1406.3852
Citation
Wacha Bounliphone, Arthur Gretton, Arthur Tenenhaus, Matthew Blaschko. A low variance consistent test of relative dependency. International Conference on Machine Learning, Jul 2015, Lille, France. ⟨hal-01005828v4⟩
Share
Metrics
Record views
846
Files downloads
538
