Limit theorems for Uprocesses . The Annals of Probability, pp.1494-1542, 1993. ,
Mapping the Origins and Expansion of the Indo-European Language Family, Science, vol.337, issue.6097, pp.337957-960, 2012. ,
DOI : 10.1126/science.1219669
A geometric approach to compare variables in a regression model, The American Statistician, vol.50, issue.1, pp.57-62, 1996. ,
Learning non-linear combinations of kernels, Neural Information Processing Systems, 2009. ,
Algorithms for learning kernels based on centered alignment, Journal of Machine Learning Research, vol.13, pp.795-828, 2012. ,
Multiple regression in psychological research and practice., Psychological Bulletin, vol.69, issue.3, p.161, 1968. ,
DOI : 10.1037/h0025471
Nonlinear canonical analysis and independence tests, The Annals of Statistics, vol.26, issue.4, pp.1254-1278, 1998. ,
DOI : 10.1214/aos/1024691242
URL : http://projecteuclid.org/download/pdf_1/euclid.aos/1024691242
Statistical consistency of kernel canonical correlation analysis, The Journal of Machine Learning Research, vol.8, pp.361-383, 2007. ,
Kernel measures of conditional dependence, Advances in Neural Information Processing Systems, pp.489-496, 2008. ,
Tumorigenesis in the brain: location, location, location. Cancer research, pp.5579-5582, 2007. ,
Language-tree divergence times support the Anatolian theory of Indo-European origin, Nature, vol.426, issue.6965, pp.426435-439, 2003. ,
DOI : 10.1038/nature02029
A simpler condition for consistency of a kernel independence test, 2015. ,
Consistent nonparametric tests of independence, Journal of Machine Learning Research, vol.11, pp.1391-1423, 2010. ,
Measuring Statistical Dependence with Hilbert-Schmidt Norms, Algorithmic Learning Theory, pp.63-77, 2005. ,
DOI : 10.1007/11564089_7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.105.477
A kernel statistical test of independence, Neural Information Processing Systems, pp.585-592, 2008. ,
Optimal kernel choice for large-scale two-sample tests, Advances in Neural Information Processing Systems, pp.1205-1213, 2012. ,
Structural modelling with sparse kernels, Machine Learning, pp.137-163, 2002. ,
A consistent multivariate test of association based on ranks of distances, Biometrika, vol.100, issue.2, pp.503-510, 2013. ,
DOI : 10.1093/biomet/ass070
Probability Inequalities for Sums of Bounded Random Variables, Journal of the American Statistical Association, vol.1, issue.301, pp.13-30, 1963. ,
DOI : 10.1214/aoms/1177730491
Equitability, mutual information, and the maximal information coefficient, Proceedings of the National Academy of Sciences, 2014. ,
DOI : 10.1073/pnas.1309933111
Europarl: A parallel corpus for statistical machine translation, MT summit, pp.79-86, 2005. ,
Expression profiling of ependymomas unravels localization and tumor gradespecific tumorigenesis, Cancer, issue.17, pp.1153955-3968, 2009. ,
Multilingual Information Retrieval: From Research to Practice, 2012. ,
DOI : 10.1007/978-3-642-23008-0
Mesenchymal Transition and PDGFRA Amplification/Mutation Are Key Distinct Oncogenic Events in Pediatric Diffuse Intrinsic Pontine Gliomas, PLoS ONE, vol.26, issue.1, p.30313, 2012. ,
DOI : 10.1371/journal.pone.0030313.s008
Detecting novel associations in large datasets, Science, issue.6062, p.334, 2011. ,
A kernel test for three-variable interactions, Neural Information Processing Systems, 2013. ,
Equivalence of distance-based and RKHS-based statistics in hypothesis testing, The Annals of Statistics, vol.41, issue.5, pp.2263-2702, 2013. ,
DOI : 10.1214/13-AOS1140
Regression Analysis ? Theory, Methods, and Applications, 2011. ,
Approximation theorems of mathematical statistics, 1981. ,
Feature selection via dependence maximization, Journal of Machine Learning Research, vol.13, pp.1393-1434, 2012. ,
Measuring and testing dependence by correlation of distances, The Annals of Statistics, vol.35, issue.6, pp.2769-2794, 2007. ,
DOI : 10.1214/009053607000000505
Sensory Cue Integration, 2011. ,
DOI : 10.1093/acprof:oso/9780195387247.001.0001
On the Convergence of Moments in the Central Limit Theorem, The Annals of Mathematical Statistics, vol.36, issue.3, pp.808-818, 1965. ,
DOI : 10.1214/aoms/1177700055
Kernel-based conditional independence test and application in causal discovery, 27th Conference on Uncertainty in Artificial Intelligence, pp.804-813, 2011. ,
