Numerical approximation of doubly reflected BSDEs with jumps and RCLL obstacles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Analysis and Applications Année : 2016
We study a discrete time approximation scheme for the solution of a doubly reflected Backward Stochastic Differential Equation (DBBSDE in short) with jumps, driven by a Brownian motion and an independent compensated Poisson process. Moreover, we suppose that the obstacles are right continuous and left limited (RCLL) processes with predictable and totally inaccessible jumps and satisfy Mokobodski's condition. Our main contribution consists in the construction of an implementable numerical sheme, based on two random binomial trees and the penalization method, which is shown to converge to the solution of the DBBSDE. Finally, we illustrate the theoretical results with some numerical examples in the case of general jumps.
dumitrescu_labart_revised3.pdf (639.06 Ko) Télécharger le fichier
hal-01006131 , version 1 (13-06-2014)
hal-01006131 , version 2 (09-12-2016)
Roxana Dumitrescu, Céline Labart. Numerical approximation of doubly reflected BSDEs with jumps and RCLL obstacles. Journal of Mathematical Analysis and Applications, 2016, 442 (1), pp.206-243. ⟨10.1016/j.jmaa.2016.03.044⟩. ⟨hal-01006131v2⟩
636 Consultations
481 Téléchargements
