Baggy bounds checking: An efficient and backwards-compatible defense against out-of-bounds errors, In SSYM, pp.51-66, 2009. ,
The static single information form, 1999. ,
Program Analysis and Specialization for the C Programming Language, 1994. ,
Introduction to the GiNaC Framework for Symbolic Computation within the C++ Programming Language, Journal of Symbolic Computation, vol.33, issue.1, pp.1-12, 2002. ,
DOI : 10.1006/jsco.2001.0494
Symbolic range propagation, Proceedings of 9th International Parallel Processing Symposium, pp.357-363, 1994. ,
DOI : 10.1109/IPPS.1995.395956
ABCD: eliminating array bounds checks on demand, PLDI, pp.321-333, 2000. ,
RICH: Automatically protecting against integer-based vulnerabilities, NDSS. USENIX, 2007. ,
Automatic construction of sparse data flow evaluation graphs, Proceedings of the 18th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '91, pp.55-66, 1991. ,
DOI : 10.1145/99583.99594
Abstract interpretation, Proceedings of the 4th ACM SIGACT-SIGPLAN symposium on Principles of programming languages , POPL '77, pp.238-252, 1977. ,
DOI : 10.1145/512950.512973
URL : https://hal.archives-ouvertes.fr/hal-01108790
Automatic discovery of linear restraints among variables of a program, Proceedings of the 5th ACM SIGACT-SIGPLAN symposium on Principles of programming languages , POPL '78, pp.84-96, 1978. ,
DOI : 10.1145/512760.512770
Why does Astr??e scale up?, Formal Methods in System Design, vol.345, issue.1, pp.229-264, 2009. ,
DOI : 10.1007/s10703-009-0089-6
Efficiently computing static single assignment form and the control dependence graph, ACM Transactions on Programming Languages and Systems, vol.13, issue.4, pp.451-490, 1991. ,
DOI : 10.1145/115372.115320
SAFECode: enforcing alias analysis for weakly typed languages, PLDI, pp.144-157, 2006. ,
Understanding Integer Overflow in C/C++, ICSE, pp.760-770, 2012. ,
DOI : 10.1145/2743019
The program dependence graph and its use in optimization, ACM Transactions on Programming Languages and Systems, vol.9, issue.3, pp.319-349, 1987. ,
DOI : 10.1145/24039.24041
Safer unsafe code for .NET, ACM SIGPLAN Notices, vol.43, issue.10, pp.329-346, 2008. ,
DOI : 10.1145/1449955.1449791
The ant and the grasshopper: fast and accurate pointer analysis for millions of lines of code, PLDI, pp.290-299, 2007. ,
LLVM: A compilation framework for lifelong program analysis & transformation, International Symposium on Code Generation and Optimization, 2004. CGO 2004., pp.75-88, 2004. ,
DOI : 10.1109/CGO.2004.1281665
Pentagons, Proceedings of the 2008 ACM symposium on Applied computing , SAC '08, pp.796-80731, 2006. ,
DOI : 10.1145/1363686.1363736
Backward under-approximations in numeric abstract domains to automatically infer sufficient program conditions, Science of Computer Programming, vol.93, 2013. ,
DOI : 10.1016/j.scico.2013.09.014
Softbound: Highly compatible and complete spatial memory safety for c, PLDI, pp.245-258, 2009. ,
Principles of program analysis, 2005. ,
DOI : 10.1007/978-3-662-03811-6
Design and implementation of sparse global analyses for c-like languages, PLDI, pp.1-11, 2012. ,
Efficient static checker for tainted variable attacks, Science of Computer Programming, vol.80, issue.1, pp.91-105, 2014. ,
DOI : 10.1016/j.scico.2013.03.012
A fast and low-overhead technique to secure programs against integer overflows, Proceedings of the 2013 IEEE/ACM International Symposium on Code Generation and Optimization (CGO), 2013. ,
DOI : 10.1109/CGO.2013.6494996
Symbolic bounds analysis of pointers, array indices, and accessed memory regions, ACM Transactions on Programming Languages and Systems, vol.27, issue.2, pp.185-235, 2005. ,
DOI : 10.1145/1057387.1057388
All You Ever Wanted to Know about Dynamic Taint Analysis and Forward Symbolic Execution (but Might Have Been Afraid to Ask), 2010 IEEE Symposium on Security and Privacy, pp.1-15, 2010. ,
DOI : 10.1109/SP.2010.26
Addresssanitizer: a fast address sanity checker, USENIX ATC, pp.28-28, 2012. ,
MemSafe: Ensuring the Spatial and Temporal Memory Safety of C at Runtime, 2010 10th IEEE Working Conference on Source Code Analysis and Manipulation, pp.93-128, 2013. ,
DOI : 10.1109/SCAM.2010.15
The atom LEAP platform for energy-efficient embedded computing, 2010. ,
Parameterized Construction of Program Representations for Sparse Dataflow Analyses, Compiler Construction, pp.2-21, 2014. ,
DOI : 10.1007/978-3-642-54807-9_2
URL : https://hal.archives-ouvertes.fr/hal-00963590
A survey of program slicing techniques, 1994. ,
Safe bounds check annotations, Concurrency and Computation: Practice and Experience, vol.12, issue.6, pp.41-57, 2009. ,
DOI : 10.1002/cpe.1341
Program Slicing, ICSE, pp.439-449, 1981. ,
DOI : 10.1109/TSE.1984.5010248
A comparison of publicly available tools for dynamic buffer overflow prevention, NDSS, pp.1-12, 2003. ,
Formal verification of ssa-based optimizations for llvm, PLDI, pp.175-186, 2013. ,
