Convergent presentations and polygraphic resolutions of associative algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematische Zeitschrift Année : 2019
Several constructive homological methods based on noncommutative Gröbner bases are known to compute free resolutions of associative algebras. In particular, these methods relate the Koszul property for an associative algebra to the existence of a quadratic Gröbner basis of its ideal of relations. In this article, using a higher-dimensional rewriting theory approach, we give several improvements of these methods. We define polygraphs for associative algebras as higher-dimensional linear rewriting systems that generalise the notion of noncommutative Gröbner bases, and allow more possibilities of termination orders than those associated to monomial orders. We introduce polygraphic resolutions of associative algebras, giving a categorical description of higher-dimensional syzygies for presentations of algebras. We show how to compute polygraphic resolutions starting from a convergent presentation, and how these resolutions can be linked with the Koszul property.
groebner.pdf (754.76 Ko) Télécharger le fichier
hal-01006220 , version 1 (14-06-2014)
hal-01006220 , version 2 (21-12-2017)
hal-01006220 , version 3 (08-10-2018)
Yves Guiraud, Eric Hoffbeck, Philippe Malbos. Convergent presentations and polygraphic resolutions of associative algebras. Mathematische Zeitschrift, 2019, 293 (1-2), pp.113-179. ⟨10.1007/s00209-018-2185-z⟩. ⟨hal-01006220v3⟩
838 Consultations
288 Téléchargements
