Some basic remarks on eigenmode expansions of time-delay dynamics, Physica A: Statistical Mechanics and its Applications, vol.373, pp.191-202, 2007. ,
DOI : 10.1016/j.physa.2005.12.073
Intrinsic parameters and stability of differential-delay equations, Journal of Mathematical Analysis and Applications, vol.163, issue.1, pp.184-199, 1992. ,
DOI : 10.1016/0022-247X(92)90287-N
Random Dynamical Systems, 1998. ,
Stability and Bifurcations in Neural Fields with Finite Propagation Speed and General Connectivity, SIAM Journal on Applied Mathematics, vol.65, issue.2, pp.644-666, 2005. ,
DOI : 10.1137/S0036139903430884
Neural Fields with Distributed Transmission Speeds and Long???Range Feedback Delays, SIAM Journal on Applied Dynamical Systems, vol.5, issue.4, pp.670-698, 2006. ,
DOI : 10.1137/050629367
Sufficient conditions for stability of linear differential equations with distributed delay. Discrete Cont, Dyn. Syst. B, vol.1, issue.2, pp.233-256, 2001. ,
Stochastic two-delay differential model of delayed visual feedback effects on postural dynamics, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.4, issue.2, pp.368423-438, 1911. ,
DOI : 10.1007/BF00346137
Delay-induced stochastic oscillations in gene regulation, Proc. Natl. Acad. Sci. USA, pp.14593-14598, 2013. ,
DOI : 10.1073/pnas.0503858102
Introduction to the numerical analysis of stochastic delay differential equations, Journal of Computational and Applied Mathematics, vol.125, issue.1-2, pp.297-307, 2000. ,
DOI : 10.1016/S0377-0427(00)00475-1
Analytical and symbolically-assisted investigations of hopf bifurcations in delay-differential equations, Canadian Applied Mathematics Quarterly, vol.3, pp.137-154, 1995. ,
Delay Equations, 1995. ,
DOI : 10.1007/978-1-4612-4206-2
Inhibitory feedback required for network oscillatory responses to communication but not prey stimuli, Nature, vol.384, issue.6922, pp.539-543, 2003. ,
DOI : 10.1126/SCIENCE.274.5288.771
Oscillatory Activity in Electrosensory Neurons Increases with the Spatial Correlation of the Stochastic Input Stimulus, Physical Review Letters, vol.93, issue.4, p.48101, 2004. ,
DOI : 10.1103/PhysRevLett.93.048101
Adiabatic elimination and reduced probability distribution functions in spatially extended systems with a fluctuating control parameter, Physical Review E, vol.64, issue.2, p.26120, 2001. ,
DOI : 10.1103/PhysRevE.64.026120
Applied Delay Differential Equations. Surveys and Tutorials in the Applied Mathematical Sciences, 2009. ,
Recurrent Inhibitory Dynamics: The Role of State-Dependent Distributions of Conduction Delay Times, Journal of Theoretical Biology, vol.216, issue.1, pp.31-50, 2002. ,
DOI : 10.1006/jtbi.2002.2534
Normal Forms for Retarded Functional Differential Equations with Parameters and Applications to Hopf Bifurcation, Journal of Differential Equations, vol.122, issue.2, p.281, 1995. ,
DOI : 10.1006/jdeq.1995.1144
Stability criteria for a class of stochastic distributed delay systems, Bulletin of the Polish Academy of Sciences: Technical Sciences, vol.61, issue.1, pp.221-228, 2013. ,
DOI : 10.2478/bpasts-2013-0021
Accurate noise projection for reduced stochastic epidemic models, Chaos: An Interdisciplinary Journal of Nonlinear Science, vol.19, issue.4, p.43110, 2009. ,
DOI : 10.1063/1.3247350
Stochastic resonance, Reviews of Modern Physics, vol.70, issue.1, pp.223-287, 1998. ,
DOI : 10.1103/RevModPhys.70.223
Bifurcation threshold of the delayed van der Pol oscillator under stochastic modulation, Physical Review E, vol.85, issue.5, p.56214, 2012. ,
DOI : 10.1103/PhysRevE.85.056214
Introduction to functional differential equations, 1993. ,
DOI : 10.1007/978-1-4612-4342-7
Measure Theory, 1974. ,
DOI : 10.1007/978-1-4684-9440-2
Local Bifurcations, Center Manifolds, and Normal Forms in Infinite-Dimensional Dynamical Systems, 2011. ,
DOI : 10.1007/978-0-85729-112-7
URL : https://hal.archives-ouvertes.fr/hal-00877080
Theory and Applications of Hopf bifurcation, 1981. ,
Effects of nonlocal feedback on traveling fronts in neural fields subject to transmission delay, Physical Review E, vol.70, issue.5, p.52902, 2004. ,
DOI : 10.1103/PhysRevE.70.052902
Additive noise may change the stability of nonlinear systems, EPL (Europhysics Letters), vol.84, issue.3, p.34003, 2008. ,
DOI : 10.1209/0295-5075/84/34003
URL : https://hal.archives-ouvertes.fr/inria-00401522
Spontaneous and evoked activity in extended neural populations with gamma-distributed spatial interactions and transmission delay, Chaos, Solitons & Fractals, vol.32, issue.2, pp.547-560, 2007. ,
DOI : 10.1016/j.chaos.2005.10.091
Delay stabilizes stochastic systems near a non-oscillatory instability, EPL (Europhysics Letters), vol.98, issue.2, 2012. ,
DOI : 10.1209/0295-5075/98/20004
Additive Global Noise Delays Turing Bifurcations, Physical Review Letters, vol.98, issue.23, p.230601, 2007. ,
DOI : 10.1103/PhysRevLett.98.230601
URL : https://hal.archives-ouvertes.fr/inria-00401534
Additive noise-induced Turing transitions in spatial systems with application to neural fields and the Swift???Hohenberg equation, Physica D: Nonlinear Phenomena, vol.237, issue.6, pp.755-773, 2008. ,
DOI : 10.1016/j.physd.2007.10.013
URL : https://hal.archives-ouvertes.fr/inria-00332982
Driving neural oscillations with correlated spatial input and topographic feedback, Physical Review E, vol.78, issue.2, p.21911, 2008. ,
DOI : 10.1103/PhysRevE.78.021911
URL : https://hal.archives-ouvertes.fr/inria-00332994
Distributed Nonlocal Feedback Delays May Destabilize Fronts in Neural Fields, Distributed Transmission Delays Do Not, The Journal of Mathematical Neuroscience, vol.3, issue.1, p.9, 2013. ,
DOI : 10.1016/j.physd.2009.09.022
URL : https://hal.archives-ouvertes.fr/hal-00847168
Langevins stochastic differential equation extended by a time-delayed term, Stochastics and Stochastic Reports, vol.111, issue.2, pp.23-42, 1992. ,
DOI : 10.1080/17442509208833780
External optical feedback effects on semiconductor injection laser properties, IEEE Journal of Quantum Electronics, vol.16, issue.3, p.347, 1980. ,
DOI : 10.1109/JQE.1980.1070479
Additive noise quenches delay-induced oscillations, EPL (Europhysics Letters), vol.102, issue.6, p.60003, 2013. ,
DOI : 10.1209/0295-5075/102/60003
URL : https://hal.archives-ouvertes.fr/hal-00847167
Reduced dynamics for delayed systems with harmonic or stochastic forcing, Chaos: An Interdisciplinary Journal of Nonlinear Science, vol.22, issue.4, p.43121, 2012. ,
DOI : 10.1063/1.4760250
URL : https://hal.archives-ouvertes.fr/hal-00764986
Time-interval sequences in bistable systems and the noise-induced transmission of information by sensory neurons, Physical Review Letters, vol.67, issue.5, pp.656-659, 1991. ,
DOI : 10.1103/PhysRevLett.67.656
The stable manifold theorem for non-linear stochastic systems with memory. I. Existence of the semiflow, Journal of Functional Analysis, vol.205, issue.2, pp.271-305, 2003. ,
DOI : 10.1016/j.jfa.2002.04.001
The stable manifold theorem for non-linear stochastic systems with memory, Journal of Functional Analysis, vol.206, issue.2, pp.253-306, 2004. ,
DOI : 10.1016/j.jfa.2003.06.002
Lyapunov Exponents and Stochastic Flows of Linear and Affine Hereditary Systems, Diffus. Proc. and Rel. Probl. of Anal., II, Stochastic Flows, pp.141-169, 1992. ,
DOI : 10.1007/978-1-4612-0389-6_7
Fluctuations and transitions at chemical instabilities: The analogy to phase transitions, The Journal of Chemical Physics, vol.61, issue.3, pp.1056-1074, 1974. ,
DOI : 10.1063/1.1681974
A Maple program for computing a terms of a center manifold, and element of bifurcations for a class of retarded functional differential equations with Hopf singularity, Applied Mathematics and Computation, vol.175, issue.2, pp.932-968, 2006. ,
DOI : 10.1016/j.amc.2005.08.013
Bifurcation analysis of a class of first-order nonlinear delay-differential equations with reflectional symmetry, Physica D: Nonlinear Phenomena, vol.166, issue.3-4, pp.131-146, 2002. ,
DOI : 10.1016/S0167-2789(02)00423-2
Simple examples of the derivation of amplitude equations for systems of equations possessing bifurcations, The Journal of the Australian Mathematical Society. Series B. Applied Mathematics, vol.27, issue.01, pp.48-65, 1985. ,
DOI : 10.1137/0143052
Rate Models with Delays and the Dynamics of Large Networks of Spiking Neurons, Progress of Theoretical Physics Supplement, vol.161, pp.68-85, 2006. ,
DOI : 10.1143/PTPS.161.68
URL : https://hal.archives-ouvertes.fr/hal-00094697
Center Manifold Theory in Infinite Dimensions, Dyn. Rep, vol.1, pp.125-163, 1992. ,
DOI : 10.1007/978-3-642-61243-5_4
Slow manifold and averaging for slow???fast stochastic differential system, Journal of Mathematical Analysis and Applications, vol.398, issue.2, pp.822-839, 2012. ,
DOI : 10.1016/j.jmaa.2012.09.029
Scheduling nonuniform traffic in a packet-switching system with small propagation delay, IEEE/ACM Transactions on Networking, vol.5, issue.6, pp.813-823, 1997. ,
DOI : 10.1109/90.650141
Delay-induced instabilities in nonlinear feedback systems, Physical Review E, vol.49, issue.1, 1994. ,
DOI : 10.1103/PhysRevE.49.203
On the low-dimensional modelling of Stratonovich stochastic differential equations, Physica A: Statistical Mechanics and its Applications, vol.225, issue.1, pp.62-80, 1996. ,
DOI : 10.1016/0378-4371(95)00387-8
Moment boundedness of linear stochastic delay differential equations with distributed delay, Stoch. Proc. Appl, vol.125, issue.1, pp.586-612, 2014. ,
