High performance concrete: early volume change and cracking tendency, Proceedings of the International RILEM Symposium ''Thermal Cracking in Concrete at Early Ages, pp.1994-229 ,
High performance concrete: field observations of cracking tendency at early ages, Proceedings of the International RILEM Symposium ''Thermal Cracking in Concrete at Early Ages, pp.1994-449 ,
From chemical and microstructural evolution of cement pastes to the development of autogenous deformations, Proceedings of the ACI Fall 2002 Convention , Session ''Autogenous deformation of concrete, 2002. ,
Lea's Chemistry of Cement and Concrete, 1998. ,
Chemical shrinkage of portland cement pastes, Cement and Concrete Research, vol.12, issue.5, pp.603-610, 1982. ,
DOI : 10.1016/0008-8846(82)90021-7
Measurements of chemical shrinkage and a systematic evaluation of hydration curves by means of the dispersion model, 1983. ,
Obtaining hydration data by measurement of chemical shrinkage with an archimeter, Cement and Concrete Research, vol.15, issue.2, pp.381-382, 1985. ,
DOI : 10.1016/0008-8846(85)90050-X
Experimental assessment of chemical shrinkage of hydrating cement pastes, Proceedings of the International Workshop on Autogenous Shrinkage of Concrete AUTOSHRINK'98, pp.81-92, 1998. ,
Special review: mathematical models of cement hydration, Cem. Res. Prog, pp.281-307, 1979. ,
Studies of the physical properties of hardened Portland cement paste, J. Am. Concr. Inst, pp.1946-1994 ,
Evolution of the Ca(OH) 2 content of different cement pastes as a function of hydration degree?Comparison between experimental and simulated results (the origin of Ca(OH) 2 appearance has been considered at 7% of hydration degree for the simulation) ,
The dispersion model for hydration of portland cement I. General concepts, Cement and Concrete Research, vol.14, issue.5, pp.622-630, 1984. ,
DOI : 10.1016/0008-8846(84)90024-3
A model for two types of calcium silicate hydrate in the microstructure of Portland cement pastes, Cement and Concrete Research, vol.30, issue.6, pp.855-863, 2000. ,
DOI : 10.1016/S0008-8846(00)00257-X
Chemistry of hydration of Portland cement, 4th International Symposium on the Chemistry of Cement, pp.429-468, 1960. ,
Influence of Cement Particle-Size Distribution on Early Age Autogenous Strains and Stresses in Cement-Based Materials, Journal of the American Ceramic Society, vol.29, issue.11, pp.129-135, 2001. ,
DOI : 10.1680/adcr.1995.7.25.33
Chemical shrinkage and autogenous shrinkage of hydrating cement paste, Cement and Concrete Research, vol.25, issue.2, pp.288-292, 1995. ,
DOI : 10.1016/0008-8846(95)00011-9
The influence of cement characteristics on chemical shrinkage, Proceedings of the International Workshop on Autogenous Shrinkage of Concrete AUTO- SHRINK'98, E & FN Spon, pp.71-80, 1998. ,
Early age autogenous shrinkage of concrete, Technical Research Centre of Finland, 2001. ,
An electronic monograph: modelling the structure and properties of cement-based materials, 1990. ,
Dissolution of cement and early chemical shrinkage of cement paste, Proceedings of Int. RILEM Workshop on Shrinkage of Concrete ''Shrinkage, pp.91-97, 2000. ,
Morphological Development of Hydrating Tricalcium Silicate as Examined by Electron Microscopy Techniques, Journal of the American Ceramic Society, vol.164, issue.3879, pp.567-572, 1981. ,
DOI : 10.1016/0008-8846(71)90032-9
The nature of the hydration products in hardened cement pastes, Cement and Concrete Composites, vol.22, issue.2, pp.97-113, 2000. ,
DOI : 10.1016/S0958-9465(99)00036-0
Chemical shrinkage of cement pastes with plasticizing admixtures, Nordic Concr. Res, pp.24-39, 2000. ,
Monitoring Portland cement hydration: Comparison of methods, Cement and Concrete Research, vol.20, issue.6, pp.919-926, 1990. ,
DOI : 10.1016/0008-8846(90)90054-2
Reaction kinetics of portland cement mortars hydrated at different temperatures, Cement and Concrete Research, vol.22, issue.1, pp.112-120, 1992. ,
DOI : 10.1016/0008-8846(92)90141-H
Hydration kinetics, change of relative humidity, and autogenous shrinkage of ultra-high-strength concrete, Cement and Concrete Research, vol.29, issue.4, pp.577-584, 1999. ,
DOI : 10.1016/S0008-8846(99)00022-8
Clinker mineral hydration at reduced relative humidities, Cement and Concrete Research, vol.29, issue.9, pp.1505-1512, 1999. ,
DOI : 10.1016/S0008-8846(99)00132-5
Degree of hydration and gel/space ratio of high-volume fly ash/cement systems, Cement and Concrete Research, vol.30, issue.5, pp.747-756, 2000. ,
DOI : 10.1016/S0008-8846(00)00213-1
Cementkemi för Byggare, Svesnka Cement Föreningen, 1956. ,
Cement Chemistry, 1990. ,
DOI : 10.1680/cc.25929
A simultaneous semi-isothermal method of thermogravimetry and derivative thermogravimetry, and its application to cement pastes, Cement and Concrete Research, vol.7, issue.3, pp.247-258, 1977. ,
DOI : 10.1016/0008-8846(77)90086-2
Mechanical Properties of Cement Pastes and Mortars at Early Ages Evolution with Time and Degree of Hydration, Advanced Cement Based Materials, vol.3, issue.3-4, pp.3-4, 1996. ,
DOI : 10.1016/1065-7355(95)00072-0
Quasielastic Neutron Scattering Study of the Effect of Water-to-Cement Ratio on the Hydration Kinetics of Tricalcium Silicate, Cement and Concrete Research, vol.28, issue.2, pp.231-243, 1998. ,
DOI : 10.1016/S0008-8846(97)00260-3
The effect of temperature on the early hydration of Portland cement and blended cements, Advances in Cement Research, vol.12, issue.3, pp.121-130, 2000. ,
DOI : 10.1680/adcr.2000.12.3.121
Total and external chemical shrinkage of low w/c ratio cement pastes, Advances in Cement Research, vol.8, issue.31, pp.121-126, 1996. ,
DOI : 10.1680/adcr.1996.8.31.121
Chemical shrinkage as an indicator of the stage of hardening, International Conference on Concrete of Early Ages, ENPC, pp.163-165, 1982. ,
Development of microstructures in plain cement pastes hydrated at different temperatures, Cement and Concrete Research, vol.21, issue.1, pp.179-189, 1991. ,
DOI : 10.1016/0008-8846(91)90044-I
