Propagation of vibrations due to a tramway line - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2008
Tramway traffic may produce vibrations propagating in soil leading to vibration annoyance for people living or working in neighbouring buildings. Thus vibration is an important parameter to be considered when planning new lines and dynamic performance evaluation of tramway tracks is necessary to validate or modify the existing means that reduce vibrations. This paper presents experimental and theoretical investigations of vibrations caused by tramway passages in Nantes, France. It focuses on the control of ground-borne vibrations for the whole system, taking into account important elements such as the dynamic vehicle characteristics, the track and the soil behaviour. A complete track-soil-ground model is proposed to predict ground-borne vibrations, so as to estimate a trouble gauge concerning - for example - the impact of a future tramway line.
MMOC.pdf (203.28 Ko) Télécharger le fichier
hal-01007536 , version 1 (17-11-2017)
Marc Maldonado, O. Chiello, Donatien Le Houedec. Propagation of vibrations due to a tramway line. Burkhard Schulte-Werning; David Thompson; Pierre-Etienne Gautier; Carl Hanson; Brian Hemsworth; James Nelson; Tatsuo Maeda; Paul de Vos. Noise and Vibration Mitigation for Rail Transportation Systems, 99, Springer Verlag, pp.158-164, 2008, Notes on Numerical Fluid Mechanics and Multidisciplinary Design 978-3-540-74893-9. ⟨10.1007/978-3-540-74893-9_22⟩. ⟨hal-01007536⟩
477 Consultations
352 Téléchargements
