Creation of a BI environment from scratch with open source software, a practical case
The purpose of this presentation is to expose a practical case and the methodology used to build a BI environment in a Research's Institute which initially didn't have a very high BI maturity. We describe here some conditions needed to succeed and the choice of open source software to build the technical BI environment.
Web
EUNIS-2014-BI-Inria-TDv1.1.pdf (104.45 Ko)
Télécharger le fichier
EUNIS-BI-ThierryDautcourt-N91.pdf (1.09 Mo)
