A decomposition of the electric field. Application to the Darwin model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 1997
In many cases, the numerical resolution of Maxwell's equations is very expensive in terms of computational cost. The Darwin model, an approximation of Maxwell's equations obtained by neglecting the divergence free part of the displacement current, can be used to compute the solution more economically. However, this model requires the electric field to be decomposed into two parts for which no straightforward boundary conditions can be derived. In this paper, we consider the case of a computational domain which is not simply connected. With the help of a functional framework, a decomposition of the fields is derived. It is then used to characterize mathematically the solutions of the Darwin model on such a domain.
Fichier non déposé
hal-01010405 , version 1 (19-06-2014)
Patrick Ciarlet, Eric Sonnendrücker. A decomposition of the electric field. Application to the Darwin model. Mathematical Models and Methods in Applied Sciences, 1997, 7 (8), pp.1085-1120. ⟨10.1142/S0218202597000542⟩. ⟨hal-01010405⟩
143 Consultations
0 Téléchargements
