Conference papers
Generalized bisimulation metrics
Abstract : The pseudometric based on the Kantorovich lifting is one of the most popular notion of distance between probabilistic processes proposed in the literature. However, its application in verification is limited to linear properties. We propose a generalization which allows to deal with a wider class of properties, such as those used in security and privacy. More precisely, we propose a family of pseudometrics, parametrized on a notion of distance which depends on the property we want to verify. Furthermore, we show that the members of this family still characterize bisimilarity in terms of their kernel, and provide a bound on the corresponding distance between trace distributions. Finally, we study the instance corresponding to differential privacy, and we show that it has a dual form, easier to compute. We also prove that the typical process-algebra constructs are non-expansive, thus paving the way to a modular approach to verification.
Document type :
Conference papers
Complete list of metadata
Cited literature [33 references]  Display  Hide  Download
https://hal.inria.fr/hal-01011471
Contributor : Catuscia Palamidessi Connect in order to contact the contributor
Submitted on : Sunday, July 3, 2016 - 7:02:16 PM
Last modification on : Friday, August 5, 2022 - 3:00:32 PM
Long-term archiving on: : Tuesday, October 4, 2016 - 10:51:05 AM
File
concur.pdf
Identifiers
Collections
Citation
Konstantinos Chatzikokolakis, Daniel Gebler, Catuscia Palamidessi, Lili Xu. Generalized bisimulation metrics. CONCUR - 25th Conference on Concurrency Theory, Sep 2014, Rome, Italy. pp.32-46, ⟨10.1007/978-3-662-44584-6_4⟩. ⟨hal-01011471⟩
Share
Metrics
Record views
487
Files downloads
484
