From Capture to Simulation - Connecting Forward and Inverse Problems in Fluids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2014
We explore the connection between fluid capture, simulation and proximal methods, a class of algorithms commonly used for inverse problems in image processing and computer vision. Our key finding is that the proximal operator constraining fluid velocities to be divergence-free is directly equivalent to the pressure-projection methods commonly used in incompressible flow solvers. This observation lets us treat the inverse problem of fluid tracking as a constrained flow problem all while working in an efficient, modular framework. In addition it lets us tightly couple fluid simulation into flow tracking, providing a global prior that significantly increases tracking accuracy and temporal coherence as compared to previous techniques. We demonstrate how we can use these improved results for a variety of applications, such as re-simulation, detail enhancement, and domain modification. We furthermore give an outlook of the applications beyond fluid tracking that our proximal operator framework could enable by exploring the connection of deblurring and fluid guiding.
FromCaptureToSimulation_Gregson2014.pdf (2.54 Mo) Télécharger le fichier
FromCaptureToSimulation_Gregson2014.avi (62.36 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-01016280 , version 1 (29-06-2014)
James Gregson, Ivo Ihrke, Nils Thuerey, Wolfgang Heidrich. From Capture to Simulation - Connecting Forward and Inverse Problems in Fluids. ACM Transactions on Graphics, 2014, Proc. ACM SIGGRAPH 2014, 33, pp.11. ⟨10.1145/2601097.2601147⟩. ⟨hal-01016280⟩
1141 Consultations
537 Téléchargements
