Regular propagators of bilinear quantum systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Functional Analysis Année : 2020
The present analysis deals with the regularity of solutions of bilinear control systems of the type $x'=(A+u(t)B)x$ where the state $x$ belongs to some complex infinite dimensional Hilbert space, the (possibly unbounded) linear operators $A$ and $B$ are skew-adjoint and the control $u$ is a real valued function. Such systems arise, for instance, in quantum control with the bilinear Schr\"{o}dinger equation. For the sake of the regularity analysis, we consider a more general framework where $A$ and $B$ are generators of contraction semi-groups. Under some hypotheses on the commutator of the operators $A$ and $B$, it is possible to extend the definition of solution for controls in the set of Radon measures to obtain precise a priori energy estimates on the solutions, leading to a natural extension of the celebrated noncontrollability result of Ball, Marsden, and Slemrod in 1982. Complementary material to this analysis can be found in [hal-01537743v1]
UP_12_12.pdf (631.09 Ko) Télécharger le fichier
hal-01016299 , version 1 (29-06-2014)
hal-01016299 , version 2 (26-10-2017)
hal-01016299 , version 3 (26-09-2019)
Nabile Boussaid, Marco Caponigro, Thomas Chambrion. Regular propagators of bilinear quantum systems. Journal of Functional Analysis, 2020, 278 (6), pp.108412. ⟨10.1016/j.jfa.2019.108412⟩. ⟨hal-01016299v3⟩
883 Consultations
395 Téléchargements
