Totally indefinite Euclidean quaternion fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Arithmetica Année : 2014
We study the Euclidean property for totally indefinite quaternion fields. In particular, we establish the complete list of norm-Euclidean such fields over imaginary quadratic number fields. This enables us to exhibit an example which gives a negative answer to a question asked by Eichler. The proofs are both theoretical and algorithmic.
quater4.pdf (251.79 Ko) Télécharger le fichier
hal-01016614 , version 1 (30-06-2014)
hal-01016614 , version 2 (24-10-2014)
hal-01016614 , version 3 (24-10-2014)
  • HAL Id : hal-01016614 , version 1
Jean-Paul Cerri, Jérôme Chaubert, Pierre Lezowski. Totally indefinite Euclidean quaternion fields. Acta Arithmetica, 2014, 164 (3), pp.653-673. ⟨hal-01016614v1⟩
212 Consultations
177 Téléchargements
