Abstract : The use of partial dynamic reconfiguration in FPGA-based systems has grown in recent years as the spectrum of applications which use this feature has increased. For these systems, it is desirable to create a series of partial bitstreams which represent tasks which can be located in multiple regions in the FPGA fabric. While the transferal of homogeneous collections of lookup-table based logic blocks from region to region has been shown to be relatively straightforward, it is more difficult to transfer partial bitstreams which contain fixed-function re- sources, such as block RAMs and DSP blocks. In this paper we consider FPGA architecture enhancements which allow for the migration of partial bitstreams including fixed-function resources from region to region even if these resources are not located in the same position in each region. Our approach does not require significant, time-consuming place-and-route during the migration process. We quantify the cost of inserting additional routing resources into the FPGA architecture to allow for easy migration of heterogeneous, fixed-function resources. Our experiments show that this flexibility can be added for a relatively low overhead and performance penalty.
