Low Power Reconfigurable Controllers for Wireless Sensor Network Nodes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A key concern in the design of controllers in wireless sensor network (WSN) nodes is the flexibility to execute different control tasks involving sensing, communications and computational resources of the node. In this paper, low power flexible controllers for WSN nodes based on reconfigurable microtasks composed of an FSM and datapath are presented. Coarse grain power gating opportunities are exploited in FSM and datapath for low power operation in reconfigurable microtasks. Power estimation results on typical benchmark microtasks show a 2× to 5× improvement in energy efficiency w.r.t a microcontroller at a cost of 5× relative to a microtask implemented as an ASIC with higher NRE costs.
tovinakere-fccm14.pdf (177.7 Ko) Télécharger le fichier
fccm_presentation.pdf (1.38 Mo) Télécharger le fichier
Format : Autre
hal-01017185 , version 1 (02-07-2014)
Vivek Tovinakere Dwarakanath, Olivier Sentieys, Steven Derrien, Christophe Huriaux. Low Power Reconfigurable Controllers for Wireless Sensor Network Nodes. FCCM - 22nd IEEE International Symposium on Field-Programmable Custom Computing Machines, May 2014, Boston, United States. pp.230-233, ⟨10.1109/FCCM.2014.68⟩. ⟨hal-01017185⟩
424 Consultations
335 Téléchargements
