On normals and projection operators for surfaces defined by point sets, Proc. of the EG conf. on Point-Based Graphics, 2004. ,
Surface reconstruction by voronoi filtering, Discrete & Computational Geometry, p.13, 1999. ,
Computing and rendering point set surfaces, Trans. on Visualization and Computer Graphics, 2003. ,
Polygon mesh repairing: An application perspective, ACM Computing Surveys (CSUR), issue.2, 2013. ,
Voronoi-based variational reconstruction of unoriented point sets, Computer Graphics Forum (Proc. of the Symposium on Geometry Processing), 2007. ,
Defining point-set surfaces, ACM Trans. on Graphics, vol.5, p.8, 2004. ,
O-snap, Proc. SIGGRAPH), p.20, 2013. ,
DOI : 10.1145/2421636.2421642
? 1 -sparse reconstruction of sharp point set surfaces Dense object reconstruction with semantic priors, CVPR, p.19, 2010. ,
A benchmark for surface reconstruction Image-based reconstruction and synthesis of dense foliage, Proc. SIGGRAPH), pp.20-21, 2013. ,
Provably good sampling and meshing of surfaces, Graphical Models, issue.7, 2005. ,
Shape analysis with subspace symmetries, Computer Graphics Forum (Proc. of Eurographics), p.16, 2011. ,
Reconstruction and representation of 3d objects with radial basis functions, Proc. of ACM SIGGRAPH, 2001. ,
Scalable realtime volumetric surface reconstruction, ACM Transactions on Graphics (TOG), p.21, 2013. ,
A volumetric method for building complex models from range images Bipartite polar classification for surface reconstruction, Proc. of ACM SIG- GRAPH CVPR, pp.13-15, 1996. ,
Ssd: Smooth signed distance surface reconstruction, Computer Graphics Forum, issue.10, 2011. ,
Point cloud skeletons via laplacian based contraction A survey of methods for moving least squares surfaces, Proc. of IEEE Shape Modeling International Proceedings of the Fifth Eurographics/IEEE VGTC conference on Point-Based Graphics Eurographics Association, p.14, 2008. ,
Curve and surface reconstruction: algorithms with mathematical analysis Feature-preserving reconstruction of singular surfaces, In Computer Graphics Forum, issue.3 4, 2007. ,
Robust smooth feature extraction from point clouds Meshflow: interactive visualization of mesh construction sequences Reconstructing surfaces using anisotropic basis functions: Model globally, match locally: Efficient and robust 3d object recognition, Proc. of Shape Modeling and Applications CVPR, pp.11-11, 2001. ,
Robust moving least-squares fitting with sharp features Robust moving least-squares fitting with sharp features Fusion of depth maps with multiple scales, Proc. SIGGRAPH)Proc. SIGGRAPH) Proc. of ACM SIGGRAPH Asia, p.12, 2005. ,
Provenance for computational tasks: A survey Gradient domain high dynamic range compression, Comp. in Science & Engineering In ACM Trans. on Graphics, vol.21, issue.10, 2002. ,
Online facade reconstruction from dominant frequencies in structured point clouds Noise-adaptive shape reconstruction from raw point sets, IEEE CVPR WorkshopsProc. of the Symposium on Geometry Processing), p.21, 2012. ,
Algebraic point set surfaces, Proc. SIGGRAPH), p.19, 2007. ,
Surface reconstruction using local shape priors Feature extraction from point clouds, Computer Graphics Forum (Proc. of the Symposium on Geometry Processing) International Meshing Roundtable, p.11, 2001. ,
Surface reconstruction from unorganized points, Computer Graphics (Proc. SIGGRAPH), 1992. ,
Robust reconstruction of watertight 3d models from non-uniformly sampled point clouds without normal information Consolidation of unorganized point clouds for surface reconstruction, Computer Graphics Forum (Proc. of the Symposium on Geometry Processing), p.11, 2006. ,
l 1 -medial skeleton of point cloud Edge-aware point set resampling Surface reconstruction from fitted shape primitives Dual contouring of hermite data, Proc. SIGGRAPH) Proc. of Vision modeling and Visualization, pp.14-15, 2002. ,
Patch-graph reconstruction for piecewise smooth surfaces 11 [Kaz05] KAZHDAN M.: Reconstruction of solid models from oriented point sets Poisson surface reconstruction, Proc. of Vision modeling and Visualization Proc. of the EG/SIGGRAPH Symposium on Geometry processing Proc. of the EG/SIGGRAPH Symposium on Geometry processing, p.20, 2005. ,
Screened poisson surface reconstruction, ACM Trans. on Graphics, vol.10, p.21, 2013. ,
Unconstrained isosurface extraction on arbitrary octrees, Symposium on Geometry Processing, 2007. ,
Acquiring 3d indoor environments with variability and repetition, Proc. of ACM SIGGRAPH Asia, vol.3, issue.18, p.21, 2012. ,
A review of vessel extraction techniques and algorithms, ACM Computing Surveys, p.14, 2004. ,
Spectral surface reconstruction from noisy point clouds, Proc. of the EG/SIGGRAPH Symposium on Geometry processing, p.12, 2004. ,
Direct visibility of point sets, Proc. SIGGRAPH), p.13, 2007. ,
Surface reconstruction through point set structuring, Proc. of Eurographics ), p.16, 2013. ,
Global optimization for shape fitting, CVPR, p.12, 2007. ,
Marching cubes: A high resolution 3d surface construction algorithm, Proc. of ACM SIGGRAPH, 1987. ,
Symmetry factored embedding and distance Error bounds and optimal neighborhoods for mls approximation, Computer Graphics Forum (Proc. of the Symposium on Geometry Processing ), 2006. ,
Datadependent MLS for faithful surface approximation Parameterization-free projection for geometry reconstruction, Computer Graphics Forum (Proc. of the Symposium on Geometry Processing )Proc. SIGGRAPH), pp.11-11, 2007. ,
Analysis, reconstruction and manipulation using arterial snakes, Proc. of ACM SIGGRAPH Asia, vol.3, issue.14, p.20, 2010. ,
Robust and efficient surface reconstruction from range data, Computer Graphics Forum, vol.12, p.16, 2009. ,
Globfit: consistently fitting primitives by discovering global relations Automatic reconstruction of tree skeletal structures from point clouds fusion for layer decomposition of urban facades, Proc. SIG- GRAPH) ICCV, pp.18-33, 2010. ,
Signing the Unsigned: Robust Surface Reconstruction from Raw Pointsets, Proc. of the Symposium on Geometry Processing), p.17, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01782.x
Streaming surface reconstruction using wavelets, Computer Graphics Forum, vol.7, issue.10, p.20, 2008. ,
Symmetry in 3d geometry: Extraction and applications, Computer Graphics Forum (STAR Proceedings of Eurographics), p.16, 2013. ,
Isosurfaces over simplicial partitions of multiresolution grids, In Computer Graphics Forum, issue.7, 2010. ,
Visibility of noisy point cloud data, Computers & Graphics, 2010. ,
A survey of urban reconstruction, Computer Graphics Forum (STAR Proceedings of Eurographics), p.7, 2013. ,
Structure-aware shape processing Abstraction of man-made shapes Kinectfusion: Real-time dense surface mapping and tracking Approximate image-based tree-modeling using particle flows Smoothing of partition of unity implicit surfaces for noise robust surface reconstruction, IEEE international symposium on Mixed and augmented reality (ISMAR) IEEE. 21 [NFD07]Proc. SIGGRAPH)Proc. of the Symposium on Geometry Processing), pp.16-31, 2007. ,
Smartboxes for interactive urban reconstruction A search-classify approach for cluttered indoor scene understanding, Proc. SIGGRAPH) Proc. of ACM SIGGRAPH Asia Real-time 3d reconstruction at scale using voxel hashing, p.21, 2010. ,
Multi-level partition of unity implicits, Proc. SIGGRAPH), 2003. ,
Multi-level partition of unity implicits Feature preserving point set surfaces based on non-linear kernel regression Indoor scene reconstruction using primitive-driven space partitioning and graphcut, Proc. SIGGRAPH) Proc. of EG workshop on Urban Data Modeling and Vis, p.16, 2003. ,
Poisson image editing, Proc. SIGGRAPH), 2003. ,
Multi-scale feature extraction on point-sampled surfaces, Computer Graphics Forum, p.11, 2003. ,
Uncertainty and variability in point cloud surface data, Proc. of the EG conf. on Point-Based Graphics, 2004. ,
Example-based 3d scan completion, Proc. of the EG/SIGGRAPH Symposium on Geometry processing, p.18, 2005. ,
Discovering structural regularity in 3d geometry, Proc. SIGGRAPH), p.16, 2008. ,
An algorithm for extracting geometric features from point cloud Modeling and visualization of leaf venation patterns Reconstructing shape boundaries with multimodal constraints, Proc. SIGGRAPH), pp.11-702, 2005. ,
Completion and reconstruction with primitive shapes Provenance for visualizations: Reproducibility and beyond, Structure recovery by part assembly. Proc. of ACM SIGGRAPH Asia, p.20, 2007. ,
Triangulating point set surfaces with bounded error, Proc. of the EG/SIGGRAPH Symposium on Geometry processing, p.15, 2005. ,
Adaptive partitioning of urban facades, Proc. of ACM SIGGRAPH Asia, p.17, 2011. ,
Competing Fronts for Coarse?to?Fine Surface Reconstruction, Proc. of Eurographics), p.15, 2006. ,
DOI : 10.1109/83.661186
Interactive topology-aware surface reconstruction, Proc. SIGGRAPH), p.20, 2007. ,
On-the-fly curve-skeleton computation for 3d shapes Interpolating and approximating implicit surfaces from polygon soup, In Computer Graphics Forum (Proc. of Eurographics) ACM Trans. on Graphics, issue.8, p.14, 2004. ,
Direct (re)meshing for efficient surface processing, Proc. of Eurographics), 2006. ,
Cone carving for surface reconstruction Efficient ransac for point-cloud shape detection, Proc. of ACM SIGGRAPH Asia Computer Graphics Forum, vol.3, issue.15, pp.13-20, 2007. ,
An interactive approach to semantic modeling of indoor scenes with an RGBD camera, ACM Transactions on Graphics, vol.31, issue.6, pp.18-21, 2012. ,
DOI : 10.1145/2366145.2366155
Vase: Volume-aware surface evolution for surface reconstruction from incomplete point clouds Curve skeleton extraction from incomplete point cloud, Proc. SIGGRAPH), pp.15-24, 2009. ,
Point-based 3d reconstruction of thin objects, ICCV, p.12, 2013. ,
Automatic extraction of manhattan-world building masses from 3d laser range scans, Trans. on Visualization and Computer Graphics, vol.7, p.17, 2012. ,
Watertight scenes from urban lidar and planar surfaces A survey on shape correspondence, STAR Proceedings of Eurographics), p.16, 2011. ,
Piecewise polynomial, positive definite and compactly supported radial functions of minimal degree, Advances in computational Mathematics, issue.9, 1995. ,
Grammar-based 3d facade segmentation and reconstruction Bandwidth selection and reconstruction quality in point-based surfaces, Computers & Graphics Trans. on Visualization and Computer Graphics, vol.17, issue.4, p.5, 2009. ,
Reconstructing the worlds museums, ECCV, p.16, 2012. ,
2.5 d building modeling by discovering global regularities, CVPR, p.17, 2012. ,
A globally optimal algorithm for robust tv-l1 range image integration, ICCV, p.12, 2007. ,
Consensus skeleton for non-rigid space-time registration Non-local scan consolidation for 3d urban scenes, Proc. SIGGRAPH), p.17, 2010. ,
