Crossing-free straight-line drawing of graphs on the flat torus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
The problem of efficiently computing straight-line drawings of planar graphs has attracted a lot of attention in the past. In this paper we took interest on straight line drawings for graphs drawn on the cylinder or on the torus. More precisely, we look at straight line drawing of unfolded periodic representations of the cylinder and the torus.
graph-drawing-on-torus.pdf (82.75 Ko) Télécharger le fichier
slides.pdf (445.28 Ko) Télécharger le fichier
Format : Figure, Image
hal-01018627 , version 1 (04-07-2014)
  • HAL Id : hal-01018627 , version 1
Luca Castelli Aleardi, Olivier Devillers, Eric Fusy. Crossing-free straight-line drawing of graphs on the flat torus. Workshop on Geometric Structures with Symmetry and Periodicity, 2014, Kyoto, Japan. ⟨hal-01018627⟩
367 Consultations
323 Téléchargements
