Voronoi diagrams and Bolza surface
The talk will show a few properties of Voronoi diagrams on the Bolza surface. Intuition is challenged there, in particular because hyperbolic translations do not commute in general.
Géométrie algorithmique [cs.CG]
teillaud.pdf (183.46 Ko)
Télécharger le fichier
teillaud-1.pdf (1.81 Mo)
Format : Figure, Image
