Ensemble Tracking, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.2, pp.261-271, 2007. ,
DOI : 10.1109/TPAMI.2007.35
Robust Object Tracking with Online Multiple Instance Learning, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.8, pp.1619-1632, 2011. ,
DOI : 10.1109/TPAMI.2010.226
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.231.5101
Probabilistic Color and Adaptive Multi-Feature Tracking with Dynamically Switched Priority Between Cues, 2007 IEEE 11th International Conference on Computer Vision, p.ICCV, 2007. ,
DOI : 10.1109/ICCV.2007.4408955
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.158.6186
Elliptical head tracking using intensity gradients and color histograms, Proceedings. 1998 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (Cat. No.98CB36231), p.CVPR, 1998. ,
DOI : 10.1109/CVPR.1998.698614
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.49.5898
Interactive graph cuts for optimal boundary & region segmentation of objects in N-D images, Proceedings Eighth IEEE International Conference on Computer Vision. ICCV 2001, p.ICCV, 2001. ,
DOI : 10.1109/ICCV.2001.937505
Object Segmentation by Long Term Analysis of Point Trajectories, p.ECCV, 2010. ,
DOI : 10.1007/978-3-642-15555-0_21
Large Displacement Optical Flow: Descriptor Matching in Variational Motion Estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.3, pp.510-513, 2011. ,
DOI : 10.1109/TPAMI.2010.143
Grabcut: Interactive foreground extraction using iterated graph cuts, ACM Trans. Graphics, 2004. ,
Online selection of discriminative tracking features, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.10, pp.1631-1643, 2005. ,
DOI : 10.1109/TPAMI.2005.205
Kernel-based object tracking, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.5, pp.564-577, 2003. ,
DOI : 10.1109/TPAMI.2003.1195991
Histograms of Oriented Gradients for Human Detection, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), p.CVPR, 2005. ,
DOI : 10.1109/CVPR.2005.177
URL : https://hal.archives-ouvertes.fr/inria-00548512
A Probabilistic Approach to Integrating Multiple Cues in Visual Tracking, p.ECCV, 2008. ,
DOI : 10.1007/978-3-540-88688-4_17
Taking the bite out of automatic naming of characters in TV video, Image and Vision Computing, vol.27, issue.5, 2009. ,
The Pascal Visual Object Classes (VOC) Challenge, International Journal of Computer Vision, vol.73, issue.2, pp.303-338, 2010. ,
DOI : 10.1007/s11263-009-0275-4
LIBLINEAR: A library for large linear classification, pp.1871-1874, 2008. ,
Object Detection with Discriminatively Trained Part-Based Models, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, issue.9, pp.1627-1645, 2010. ,
DOI : 10.1109/TPAMI.2009.167
Semi-supervised On-Line Boosting for Robust Tracking, p.ECCV, 2008. ,
DOI : 10.1007/978-3-540-88682-2_19
Some network flow problems solved with pseudo-boolean programming, Operations Research, vol.13, pp.388-399, 1965. ,
Struck: Structured output tracking with kernels, p.ICCV, 2011. ,
DOI : 10.1109/iccv.2011.6126251
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.294.5858
Multiple View Geometry in Computer Vision, 2004. ,
DOI : 10.1017/CBO9780511811685
Icondensation: Unifying low-level and high-level tracking in a stochastic framework, p.ECCV, 1998. ,
DOI : 10.1007/BFb0055711
Robust online appearance models for visual tracking, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.10, pp.1296-1311, 2003. ,
DOI : 10.1109/TPAMI.2003.1233903
Tracking-Learning-Detection, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.34, issue.7, pp.1409-1422, 2012. ,
DOI : 10.1109/TPAMI.2011.239
What energy functions can be minimized via graph cuts? PAMI, pp.147-159, 2004. ,
DOI : 10.1109/tpami.2004.1262177
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.113.1823
Visual tracking and recognition using probabilistic appearance manifolds, Computer Vision and Image Understanding, vol.99, issue.3, pp.303-331, 2005. ,
DOI : 10.1016/j.cviu.2005.02.002
Coupled Object Detection and Tracking from Static Cameras and Moving Vehicles, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.10, pp.1683-1698, 2008. ,
DOI : 10.1109/TPAMI.2008.170
Track to the future: Spatio-temporal video segmentation with long-range motion cues, CVPR 2011, p.CVPR, 2011. ,
DOI : 10.1109/CVPR.2011.6044588
URL : https://hal.archives-ouvertes.fr/hal-00817961
Robust Visual Tracking Using Local Sparse Appearance Model and K-Selection, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.35, issue.12, pp.2968-2981, 2013. ,
DOI : 10.1109/TPAMI.2012.215
An iterative image registration technique with an application to stereo vision, p.IJCAI, 1981. ,
Ensemble of exemplar-SVMs for object detection and beyond, 2011 International Conference on Computer Vision, p.ICCV, 2011. ,
DOI : 10.1109/ICCV.2011.6126229
The template update problem, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.6, pp.810-815, 2004. ,
DOI : 10.1109/TPAMI.2004.16
Robust visual tracking and vehicle classification via sparse representation, PAMI, vol.33, issue.11, pp.2259-2272, 2011. ,
Dependent Multiple Cue Integration for Robust Tracking, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.30, issue.4, pp.670-685, 2008. ,
DOI : 10.1109/TPAMI.2007.70727
Segmentation of Moving Objects by Long Term Video Analysis, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.36, issue.6, pp.1187-1200, 2014. ,
DOI : 10.1109/TPAMI.2013.242
Finding the Best from the Second Bests - Inhibiting Subjective Bias in Evaluation of Visual Tracking Algorithms, 2013 IEEE International Conference on Computer Vision, p.ICCV, 2013. ,
DOI : 10.1109/ICCV.2013.346
Robust visual tracking using autoregressive hidden Markov model, p.CVPR, 2012. ,
Data Fusion for Visual Tracking With Particles, Proceedings of the IEEE, vol.92, issue.3, pp.495-513, 2004. ,
DOI : 10.1109/JPROC.2003.823147
Probabilistic outputs for support vector machines and comparisons to regularized likelihood methods, p.NIPS, 1999. ,
Tracking People by Learning Their Appearance, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.1, pp.65-81, 2007. ,
DOI : 10.1109/TPAMI.2007.250600
Incremental Learning for Robust Visual Tracking, International Journal of Computer Vision, vol.61, issue.3, pp.125-141, 2008. ,
DOI : 10.1007/s11263-007-0075-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.139.4310
Tracking Revisited Using RGBD Camera: Unified Benchmark and Baselines, 2013 IEEE International Conference on Computer Vision, p.ICCV, 2013. ,
DOI : 10.1109/ICCV.2013.36
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.300.921
Towards robust multi-cue integration for visual tracking. Machine Vis, App, vol.14, pp.50-58, 2003. ,
Learning to track with multiple observers, 2009 IEEE Conference on Computer Vision and Pattern Recognition, p.CVPR, 2009. ,
DOI : 10.1109/CVPR.2009.5206634
Dense Point Trajectories by GPU-Accelerated Large Displacement Optical Flow, p.ECCV, 2010. ,
DOI : 10.1007/978-3-642-15549-9_32
Self-Paced Learning for Long-Term Tracking, 2013 IEEE Conference on Computer Vision and Pattern Recognition, p.CVPR, 2013. ,
DOI : 10.1109/CVPR.2013.308
Detection and Tracking of Multiple, Partially Occluded Humans by Bayesian Combination of Edgelet based Part Detectors, International Journal of Computer Vision, vol.I, issue.4, 2007. ,
DOI : 10.1007/s11263-006-0027-7
Online Object Tracking: A Benchmark, 2013 IEEE Conference on Computer Vision and Pattern Recognition, p.CVPR, 2013. ,
DOI : 10.1109/CVPR.2013.312
Object tracking, ACM Computing Surveys, vol.38, issue.4, 2006. ,
DOI : 10.1145/1177352.1177355
