S. F. Boll, Suppression of acoustic noise in speech using spectral subtraction, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.27, issue.2, pp.113-120, 1979.
DOI : 10.1109/TASSP.1979.1163209
R. Martin, Spectral subtraction based on minimum statistics, Proc.EUSIPCO, pp.1982-1185, 1994.
Y. Ephraim and D. Malah, Speech enhancement using a minimum-mean square error short-time spectral amplitude estimator, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.32, issue.6, pp.1109-1121, 1984.
DOI : 10.1109/TASSP.1984.1164453
D. E. Dudgeon and D. H. Johnson, Array Signal Processing: Concepts and Techniques, 1993.
F. Itakura and S. Saito, Analysis synthesis telephony based on the maximum likelihood method, Rep. 6th International Congress on Acoustics, pp.17-20, 1968.
