Fault Detection and State Evaluation of Rotor Blades - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The present work has been done within the Joint Research Project Blade Tester, which develops an approach for cost-effective, serial integrity tests of rotor blades. At that, manufacturing faults shall be automatically detected, localized and assessed with respect to their impact on the integrity of rotor blades in operation. Several techniques are involved and discussed in the contribution, such as 3D full-scale geometry measurement, structural modelling by the finite element method and model validation, fibre optical sensing, several non-destructive testing techniques and parameter identification on the basis of static and dynamic tests.
0465.pdf (1011.29 Ko) Télécharger le fichier
hal-01020388 , version 1 (08-07-2014)
  • HAL Id : hal-01020388 , version 1
Yuri Petryna, Andreas Künzel, Matthias Kannenberg. Fault Detection and State Evaluation of Rotor Blades. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01020388⟩
673 Consultations
210 Téléchargements
