A novel imaging technique for SHM using sparse and compact arrays, Proceedings of the SPIE Health Monitoring of Structural and Biological System, p.14, 2011. ,
Structural health monitoring strategy for detection of interlaminar delamination in composite plates, Health Monitoring of Structural and Biological Systems 2011, pp.19-30, 2011. ,
DOI : 10.1117/12.880532
Methodology for optimal configuration in structural health monitoring of composite bonded joints, Smart Materials and Structures, vol.21, issue.10, p.2012 ,
DOI : 10.1088/0964-1726/21/10/105001
Pitch-catch Active Sensing Methods in Structural Health Monitoring for Aircraft Structures, Structural Health Monitoring, vol.7, issue.1, p.11, 2008. ,
DOI : 10.1177/1475921707081979
Piezoelectric Wafer Embedded Active Sensors for Aging Aircraft Structural Health Monitoring, Structural Health Monitoring, vol.1, issue.1, p.20, 2002. ,
DOI : 10.1177/147592170200100104
Structural Health Monitoring with Piexoelectric Wafer Active sensors, 2008. ,
Dispersion-based imaging for structural health monitoring using sparse and compact arrays, Smart Materials and Structures, vol.20, issue.2, p.12, 2011. ,
DOI : 10.1088/0964-1726/20/2/025005
A rapid signal processing technique to remove the effect of dispersion from guided wave signals, IEEE Transactions on Ultrasonics, Ferroelectrics and Frequency Control, vol.50, issue.4, 2003. ,
DOI : 10.1109/TUFFC.2003.1197965
Rapid localization of damage using a circular sensor array and Lamb wave based triangulation, Mechanical Systems and Signal Processing, pp.24-41, 2010. ,
DOI : 10.1016/j.ymssp.2010.06.002
Tuned lamb wave excitation and detection with piezo-electric wafer active sensors for structural health monitoring, Journal of Intelligent Material Systems and Structures, vol.16, issue.4, 2005. ,
Improved damage imaging in aerospace structures using a piezoceramic hybrid pin-force wave generation model, Proceedings of the SPIE conferences, pp.12-2014 ,
In-situ mechanical characterization of isotropic structures using guided wave propagation, Smart Materials and Structures, p.2012 ,
Finite-Dimensionsl Piezoelectric Trandsucer Modelling for Guided Wave based Structural Health Monitoring, Smart Materials and Structures, vol.14, p.13, 2005. ,
Shear lag solution for tuning ultrasonic piezoelectric wafer active sensors with applications to Lamb wave array imaging, International Journal of Engineering Science, vol.48, issue.10, p.13, 2010. ,
DOI : 10.1016/j.ijengsci.2010.05.007
Lamb wave tuning curve calibration for surface-bonded piezoelectric transducers, Smart Materials and Structures, vol.19, issue.1, p.15, 2010. ,
DOI : 10.1088/0964-1726/19/1/015007
Correlation-based imaging algorithm for fatigue monitoring of riveted lap-joint structure, Smart Materials and Structures, vol.23, p.15, 2014. ,
Optimization of lamb wave inspection techniques, NDT & E International, vol.25, issue.1, p.12, 1992. ,
DOI : 10.1016/0963-8695(92)90003-Y
Approaches to hybrid SHM and NDE of composite aerospace structures, Proceedings of the SPIE conferences 2014, 2014. ,
Damage identification of metallic structures using A0 mode of lamb waves, Structural Health Monitoring, vol.7, p.15, 2008. ,
Broadband generation of ultrasonic guided waves using piezoceramics and sub-band decomposition, IEEE Transactions on Ultrasonics, Ferroelectrics and Frequency Control, vol.59, issue.5, p.10, 2012. ,
DOI : 10.1109/TUFFC.2012.2277
