Image Correlation for Shape Motion and Deformation Measurements. Basic Concepts, Theory and Application, 1st Editio, 2009. ,
Experimental characterization of frictional behaviour of clutch facings using Pin-on-disk machine A numerical study on the coefficients of thermal expansion of fiber reinforced composite materials, Mater. Des. Compos. strucutres, vol.284, issue.78, pp.2148-2153, 2007. ,
Digital image correlation applied to thermal expansion of composites, ICCM, pp.5235-5243, 2013. ,
Effect of Thermal Cycling on the Mechanical Properties of a Continuous Fibre Composite Used for Car Clutch Facings, Advanced Materials Research, vol.891, issue.892, pp.42-47, 2014. ,
DOI : 10.4028/www.scientific.net/AMR.891-892.42
