Conference papers
Monitoring of Inflatable Structures by Using Virtual Image Correlation
Abstract : The VIC method consists in finding the analytical contour by fitting the boundary of the objet in the picture as best as possible. It has been used for shape measurement of an inflatable beam submitted to a transverse wind in the CSTB wind tunnel in Nantes. The principle and the main equations of the method are recalled. The originality of this study is that the equation of the contour is deduced from the analytical expression of the deformation of an inflatable beam under a distributed constant (aerodynamic) load. This acts as a powerful mechanical-based filter and leads straightforwardly to the researched mechanical properties of the textile membrane.
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/hal-01020416
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Tuesday, July 8, 2014 - 10:09:45 AM
Last modification on : Wednesday, January 19, 2022 - 3:48:04 PM
Long-term archiving on: : Wednesday, October 8, 2014 - 12:06:31 PM
File
0361.pdf
Identifiers
  • HAL Id : hal-01020416, version 1
Citation
Alexis Bloch, Marc François, Jean-Christophe Thomas, Olivier Flamand. Monitoring of Inflatable Structures by Using Virtual Image Correlation. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01020416⟩
Share
Metrics
Les métriques sont temporairement indisponibles
