Flexible Gabion Structures in Earth Retaining Works, 1987. ,
A scaling method for modelling the crashworthiness of novel roadside barrier designs Available at http://dx Atahan, Finite-element crash test simulation of New York Portable Concrete Barrier with Ishaped connector, International Journal of Crashworthiness Journal of Structural Engineering-Asce, vol.18132, issue.132430, pp.93-102, 2006. ,
Computer simulation of the impact performance of a wire rope safety fence, International Journal of Impact Engineering, vol.257, issue.00, pp.67-85, 2001. ,
Multibody analysis of m3 bus rollover: structural behaviour and passenger injury risk, 18th International Technical Conference on the Enhanced Safety of Vehicles -ESV, p.12, 2003. ,
Simulation of crash tests for high containment levels of road safety barriers Available at http://www.sciencedirect.com/science, S1350630706002317. [9] C.S. Clarke, Composite test report for test number M0044, 1.5t car/113km/h impact speed/20° impact angle impacting temporary vertical concrete barrier (non standard washers, pp.1711-1718, 1994. ,
Performance limit analysis for common roadside and median barriers using LS-DYNA, International Journal of Crashworthiness, vol.970, issue.6, pp.691-706, 2011. ,
DOI : 10.3141/1690-10
Evaluation of Portable Concrete Barriers Using Finite Element Simulation, Transportation Research Record: Journal of the Transportation Research Board, vol.1720, pp.1-6, 2000. ,
DOI : 10.3141/1720-01
