Monitoring of a Large Cracked Concrete Sample with Non-Linear Mixing of Ultrasonic Coda Waves
Abstract : A high precision can be achieved with ultrasonic coda waves to monitor the mechanical properties of concrete material (~10-5 in relative). This high sensitivity can be used to detect damage initiation and to closely follow concrete mechanical properties evolution with time. This advantage is counterbalance by the influence of environmental conditions making reproducibility of any experiment in concrete a challenging issue especially when in situ measurements are performed. Indeed thermal and water gradients present in the thickness of the structures (several decimetres) cannot be controlled and must be compensated. In this paper a protocol to remove environmental bias is proposed. Furthermore, to follow the apparition of a tensile crack in a metric size structure, non-linear mixing of coda wave via frequency-swept pump waves is tested. It is shown that, when the crack is closed (by pre-stressing cables), it is still possible to detect its presence. The non-linearity of the cracked zone remains at a high level, comparable to the case when the crack was open.
Type de document :
Communication dans un congrès
Le Cam, Vincent and Mevel, Laurent and Schoefs, Franck. EWSHM - 7th European Workshop on Structural Health Monitoring, Jul 2014, Nantes, France. 2014
Liste complète des métadonnées
Littérature citée [18 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01021034
Contributeur : Anne Jaigu <>
Soumis le : mercredi 9 juillet 2014 - 08:38:29
Dernière modification le : mardi 12 juin 2018 - 10:28:04
Document(s) archivé(s) le : jeudi 9 octobre 2014 - 10:46:46
Fichier
0399.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01021034, version 1
Citation
Odile Abraham, Yuxiang Zhang, Xavier Chapeleau, Olivier Durand, Vincent Tournat. Monitoring of a Large Cracked Concrete Sample with Non-Linear Mixing of Ultrasonic Coda Waves. Le Cam, Vincent and Mevel, Laurent and Schoefs, Franck. EWSHM - 7th European Workshop on Structural Health Monitoring, Jul 2014, Nantes, France. 2014. 〈hal-01021034〉
Métriques
Consultations de la notice
1157
Téléchargements de fichiers
196
