Automatic choice of measurement locations for dynamic testing, AIAA Journal, vol.32, issue.2, pp.407-414, 1994. ,
DOI : 10.2514/3.11998
Robutness of optimal sensor placement under parametric uncertainty, Mechanical Systems and Signal Processing, pp.41-268, 2013. ,
Polymax: a revolution in operational modal analysis, Proccedings of the IOMAC, International Operational Modal Analysis Conference, 2005. ,
Cubierta para un recinto multifuncional abierto con cuatro paraboloides hiperb??licos textiles, Informes de la Construcción, pp.437-444, 2012. ,
DOI : 10.3989/ic.11.124
Sensor placement for on-orbit modal identification and correlation of large space structures, Journal of Guidance, Control, and Dynamics, vol.14, issue.2, pp.2984-2990, 1990. ,
DOI : 10.2514/3.20635
Project function: Eventual cover. Construction year: 2010. Architects: Félix Escrig and José Sánchez. Engineering: Performance Ideas y Aplicaciones S.L. performance@arquired.es. Prime contractor: SANROCON S.A. sanrocon@sanrocon.com. Fabric contractor ,
