Numerical Computation of the Nonlinear Far Field of Ultrasonic Waves Scattered by Closed Cracks of Various Orientations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The directivity patterns of the higher harmonics generated by the interaction between a bulk wave and a closed crack are obtained in the far field. A Finite Element (FE) model gives the near field solution which is then analytically propagated with expressions based on Hankel functions. The crack is modeled by an interface of unilateral contact with CoulombÕs friction which takes into account a compression pre-stress s0 that closes the crack. The mode conversion occurring at the crack investigated. Moreover, the diffracted fields of the generated higher harmonics are compared to those of the fundamental harmonic.
0377.pdf (189.62 Ko) Télécharger le fichier
hal-01021070 , version 1 (09-07-2014)
  • HAL Id : hal-01021070 , version 1
Philippe Blanloeuil, Anissa Meziane, Andrew N. Norris, Mathieu Renier, Martin Veidt. Numerical Computation of the Nonlinear Far Field of Ultrasonic Waves Scattered by Closed Cracks of Various Orientations. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021070⟩
388 Consultations
214 Téléchargements
