Conference papers
Statistical Impact-Echo Analysis Based on Grassmann Manifold Learning: Its Preliminary Results for Concrete Condition Assessment
Abstract : Impact-echo is one extensively applied non-destructive technique for flaw detection in concrete structures. In impact-echo test, surface motion generated by short-duration mechanical impact is investigated for structural condition assessment. This paper endeavours to formulate impact echo analysis by using novel statistical techniques, i.e. Grassmann manifold learning. Comparing to conventional impact-echo test, the proposed method presents several favourable properties: 1. Conventional impact-echo method mostly relies on frequency peak in echo spectrum, the proposed method characterizes rich temporal-spectral patterns in addition to the spectral peak. 2. Proposed method is performed over local area on concrete surface with integration of several consecutive echo responses, and thus produces more stable condition evaluation result comparing to point-wise impact-echo approach. 3. To cope with extracted echo feature, effective similarity metric on Grassmann manifold is employed, which favourably facilities condition-based assessment. To demonstrate the proposed method, we prepared concrete specimen with 2cm, 4cm and 6cm depth void inside and echo signal is captured through air-coupled sensor. Experimental result demonstrates the effectiveness of the proposed method, including accurate condition-based classification performance and high processing efficiency
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01021193
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Wednesday, July 9, 2014 - 10:17:43 AM
Last modification on : Saturday, December 19, 2020 - 11:08:03 AM
Long-term archiving on: : Tuesday, April 11, 2017 - 11:56:17 AM
File
0425.pdf
Identifiers
  • HAL Id : hal-01021193, version 1
Collections
Citation
Jiaxing Ye, Masaya Iwata, Kobayashi Takumi, Masahiro Murakawa, Higuchi Tetsuya, et al.. Statistical Impact-Echo Analysis Based on Grassmann Manifold Learning: Its Preliminary Results for Concrete Condition Assessment. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021193⟩
Share
Metrics
Record views
313
Files downloads
308
