HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
A Time-Domain High-Order Spectral Finite Element for the Simulation of Symmetric and Anti-Symmetric Guided Waves in Laminated Composite Strips with Active Piezoelectric Sensors
Abstract : A new time domain spectral finite element is developed for improving the efficiency of numerical simulations of guided waves in laminated composite strips. The finite element relies on a new generalized laminate mechanics model formulated to represent symmetric and anti-symmetric Lamb waves. The laminate mechanics incorporate third-order polynomial terms for the approximation of axial and transverse displacement fields through the thickness, and consider the displacements of the upper and lower surfaces as degrees of freedom. Based on the resultant governing equations of the laminate section, a new finite element with 8 nodal degrees of freedom is formulated, with its nodes collocated with Gauss-Lobatto-Legendre integration points. Stiffness and mass matrices are assembled and the transient response is predicted with explicit central differences time integration. The transient response of an orthotropic composite strip exited by a 5-count Gaussian pulse is investigated. Results are validated against a semi-analytical solution Numerical results exhibit substantial improvement in the convergence and accuracy of the introduced element regarding the prediction of symmetric and anti-symmetric wave propagation.
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01021224
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Wednesday, July 9, 2014 - 10:24:06 AM
Last modification on : Tuesday, December 26, 2017 - 4:38:01 PM
Long-term archiving on: : Thursday, October 9, 2014 - 11:25:17 AM
File
0263.pdf
Identifiers
  • HAL Id : hal-01021224, version 1
Collections
Citation
Christoforos Rekatsinas, Christos Nastos, Theodosis Theodosiou, Dimitris Saravanos. A Time-Domain High-Order Spectral Finite Element for the Simulation of Symmetric and Anti-Symmetric Guided Waves in Laminated Composite Strips with Active Piezoelectric Sensors. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021224⟩
Share
Metrics
Record views
225
Files downloads
203
