Finite difference method (Part III) In : Handbook of Computentional Solid Mechanics, pp.336-432, 1998. ,
High-frequency Dispersion Characteristics of Smart Delaminated Composite Beams, Journal of Intelligent Material Systems and Structures, vol.20, issue.9, pp.1057-1068, 2009. ,
DOI : 10.1177/1045389X09102983
Dispertion Analysis of Finite Emenet Semidiscretizations of the Two- Dimentional Wave Equation, International Journal of Numerical Methods in Engineering, pp.11-29, 1982. ,
Numerical determination of modal dispersion and AE signal characterization in waveguides through LBIE/BEM and time???frequency analysis, Computational Mechanics, vol.39, issue.3, pp.431-441, 2009. ,
DOI : 10.1007/s00466-008-0318-7
Wave propagation modelling in 1D structures using spectral finite elements, Journal of Sound and Vibration, vol.300, issue.1-2, pp.88-100, 2007. ,
DOI : 10.1016/j.jsv.2006.07.031
Wave Propagation in Structures, 1997. ,
A spectral element method for fluid dynamics: Laminar flow in a channel expansion, Journal of Computational Physics, vol.54, issue.3, pp.468-488, 1984. ,
DOI : 10.1016/0021-9991(84)90128-1
Modelling of wave propagation in composite plates using the time domain spectral element method, Journal of Sound and Vibration, vol.302, issue.4-5, pp.728-745, 2007. ,
DOI : 10.1016/j.jsv.2006.12.016
Investigation on Wave Behaviour at Defects in 2D Composite Structures Using Spectral Finite Elements in the Time Domain, 6th European Workshop on Structural Health Monitoring, pp.269-276, 2012. ,
Optimizing a spectral element for modeling PZT-induced Lamb wave propagation in thin plates, Smart Materials and Structures, vol.19, 2010. ,
High-order layerwise mechanics and finite element for the damped dynamic characteristics of sandwitch composite beams, International Journal of Solids and Structures, pp.6853-6871, 2004. ,
Wave Motion in Elastic Solids, 1991. ,
Coupled Layerwise Analysis of Composite Beams with Embedded Piezoelectric Sensors and Actuators, Journal of Intelligent Material Systems and Structures, vol.25, issue.1, pp.350-363, 1995. ,
DOI : 10.1177/1045389X9500600306
Introduction to Finite Elements in Enfineering, 1991. ,
Certain numerical issues of wave propagation modelling in rods by the Spectral Finite Element Method. Finite Elements in Analysis and Design, pp.1036-1046, 2011. ,
Exact Shear-Lag Solution for Guided Waves Tuning with Piezoelectric-Wafer Active Sensors, AIAA Journal, vol.50, issue.11, pp.2285-2294, 2012. ,
DOI : 10.2514/1.J050667
Piezoelectric transducer arrangement for the inspection of large composite structures, Composites Part A: Applied Science and Manufacturing, vol.38, issue.4, pp.1121-1130, 2007. ,
DOI : 10.1016/j.compositesa.2006.06.011
A Semi-Analytical Layerwise Solution for the Wave Propagation along a Semi-Infinite Strip with Capabilities of Damage Detection, EWSHM ,
