Stochastic Finite Element Buckling Analysis of Laminated Plates With Circular Cutout Under Uniaxial Compression, Journal of Applied Mechanics, vol.74, issue.4, pp.798-809, 2007. ,
DOI : 10.1115/1.2711230
Uncertainty handling in structural damage detection using fuzzy logic and probabilistic simulation, Mechanical Systems and Signal Processing, vol.23, issue.2, pp.384-404, 2009. ,
DOI : 10.1016/j.ymssp.2008.03.013
Nonlinear vibration analysis of composite laminated and sandwich plates with random material properties, International Journal of Mechanical Sciences, vol.52, issue.7, pp.874-891, 2010. ,
DOI : 10.1016/j.ijmecsci.2010.03.002
Non-linear vibration analysis of smart composite structures with discrete delamination using a refined layerwise theory, Journal of Sound and Vibration, vol.273, issue.1-2, pp.387-407, 2004. ,
DOI : 10.1016/S0022-460X(03)00561-3
Free vibration analysis of composite sandwich plates based on Reddy's higher-order theory, Composites Part B: Engineering, vol.33, issue.7, pp.505-519, 2002. ,
DOI : 10.1016/S1359-8368(02)00035-5
