A review on machinery diagnostics and prognostics implementing condition-based maintenance, Mechanical Systems and Signal Processing, vol.20, issue.7, pp.1483-1510, 2006. ,
DOI : 10.1016/j.ymssp.2005.09.012
Condition Monitoring Using Computational Intelligence Methods ,
DOI : 10.1007/978-1-4471-2380-4
A review of process fault detection and diagnosis, Computers & Chemical Engineering, vol.27, issue.3, pp.293-311, 2003. ,
DOI : 10.1016/S0098-1354(02)00160-6
Recent advances in time???frequency analysis methods for machinery fault diagnosis: A review with application examples, Mechanical Systems and Signal Processing, vol.38, issue.1, pp.165-205, 2013. ,
DOI : 10.1016/j.ymssp.2013.01.017
Monitoring, fault diagnosis, fault-tolerant control and optimization: Data driven methods, Computers & Chemical Engineering, vol.47, pp.111-120, 2012. ,
DOI : 10.1016/j.compchemeng.2012.06.017
Residual-based fault detection using soft computing techniques for condition monitoring at rolling mills, Information Sciences, vol.259, pp.304-320, 2014. ,
DOI : 10.1016/j.ins.2013.06.045
Wind turbine fault detection using multiwavelet denoising with the data-driven block threshold, Applied Acoustics, vol.77, pp.122-129, 2014. ,
DOI : 10.1016/j.apacoust.2013.04.016
Multi-fault diagnosis study on roller bearing based on multi-kernel support vector machine with chaotic particle swarm optimization, Measurement, vol.47, pp.576-590, 2014. ,
DOI : 10.1016/j.measurement.2013.08.021
On-line chatter detection and identification based on wavelet and support vector machine, Journal of Materials Processing Technology, vol.210, issue.5, pp.713-719, 2010. ,
DOI : 10.1016/j.jmatprotec.2009.11.007
Chatter identification in end milling process using wavelet packets and Hilbert???Huang transform, International Journal of Machine Tools and Manufacture, vol.69, pp.11-19, 2013. ,
DOI : 10.1016/j.ijmachtools.2013.02.007
An approach to vibration analysis using wavelets in an application of aircraft health monitoring, Mechanical Systems and Signal Processing, vol.21, issue.3, pp.1255-1320, 2007. ,
DOI : 10.1016/j.ymssp.2006.06.008
The empirical mode decomposition and the Hilbert spectrum for nonlinear and non-stationary time series analysis, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.454, issue.1971, pp.903-995, 1998. ,
DOI : 10.1098/rspa.1998.0193
A review on empirical mode decomposition in fault diagnosis of rotating machinery, Mechanical Systems and Signal Processing, vol.35, issue.1-2, pp.108-126, 2013. ,
DOI : 10.1016/j.ymssp.2012.09.015
Support Vector Machines for Pattern Classification, 2010. ,
DOI : 10.1007/978-1-84996-098-4
