Conference papers
Damage Detection in Metallic Beams from Dynamic Strain Measurements under Different Load Cases by Using Automatic Clustering and Pattern Recognition Techniques
Abstract : In general, the change in the local strain field or global stiffness caused by damage in a structure is very small and the strain field tends to homogenize very quickly in the field close to the defect. Moreover, other environmental effects can fade the slight changes in the strain field. Only by comparing the response of the structure at several points some information about damage may be unveiled. By means of pattern recognition techniques based on the strain field, this task can be achieved. This is the basis of the strain measurements data-driven models. The main limitation of the strain field pattern recognition techniques lies in the susceptibility of the strain field to change depending on the load conditions. In the case of dynamic loads, this may reflect even a greater limitation. Robust automated techniques are required to manage these limitations. In first instance, automatic clustering techniques are needed so that data can be classified according to the load conditions and secondly, a dimensional reduction technique is needed in order to obtain patterns that often underlie from data. Within the context of this paper, a combination of Local Density-based Simultaneous Two-Level (DS2L-SOM) Clustering based on Self-Organizing Maps (SOM) and Principal Components Analysis (PCA) is proposed in order to firstly, classify load conditions and secondly, perform strain field pattern recognition. The clustering technique is the basis for an Optimal Baseline Selection. An experimental validation of the technique is discussed in this paper, comparing damages of different sizes and positions in an aluminum beam, under a set of combined loads under dynamic conditions. Strains were measured at several points by using Fiber Bragg Gratings.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01021236
Contributor : Anne Jaigu Connect in order to contact the contributor
Submitted on : Wednesday, July 9, 2014 - 10:24:49 AM
Last modification on : Saturday, June 25, 2022 - 8:54:33 PM
Long-term archiving on: : Thursday, October 9, 2014 - 11:28:45 AM
File
0104.pdf
Identifiers
  • HAL Id : hal-01021236, version 1
Citation
Julian Sierra-Pérez, Miguel Angel Torres-Arredondo, Guénaël Cabanes, Alfredo Güemes, Luis Eduardo Mujica, et al.. Damage Detection in Metallic Beams from Dynamic Strain Measurements under Different Load Cases by Using Automatic Clustering and Pattern Recognition Techniques. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021236⟩
Share
Metrics
Record views
388
Files downloads
288
