Estimating fatigue life with particular emphasis on cumulative damage, Metal Fatigue, 1959. ,
Die Lebensdauer von Kugellagern, p.68, 1924. ,
On-line Monitoring of Wind Induced Stresses and Fatigue Damage in Structures, Journal of Structural Control and Health Monitoring, 2012. ,
Fatigue predictions in entire body of metallic structures from a limited number of vibration sensors using Kalman filtering, Structural Control and Health Monitoring, vol.278, issue.4, pp.554-573, 2010. ,
DOI : 10.1002/stc.395
Optimal State Estimation, 2006. ,
DOI : 10.1002/0470045345
A New Approach to Linear Filtering and Prediction Problems, Journal of Basic Engineering, vol.82, issue.1, pp.35-45, 1960. ,
DOI : 10.1115/1.3662552
Optimal model-based state estimation in mechanical and structural systems, Structural Control and Health Monitoring, vol.83, issue.3, pp.532-543, 2013. ,
DOI : 10.1002/stc.513
Do All Linear Flexible Structures Have Convergent Second-Order Observers?, Journal of Guidance, Control, and Dynamics, vol.22, issue.6, pp.905-908, 1999. ,
DOI : 10.2514/2.4468
Wind Effects on Structures, 1996. ,
Digital simulation of wind field velocity, Journal of Wind Engineering and Industrial Aerodynamics, vol.74, issue.76, pp.74-76, 1998. ,
DOI : 10.1016/S0167-6105(98)00008-7
Convergence Properties of the Nelder--Mead Simplex Method in Low Dimensions, SIAM Journal on Optimization, vol.9, issue.1, pp.112-147, 1998. ,
DOI : 10.1137/S1052623496303470
Fatigue life under along-wind loading -closed-form solutions. Engineering Structures, pp.109-114, 2002. ,
