A review of vibration-based structural health monitoring with special emphasis on composite materials. The Shock and Vibration Digest, pp.295-324, 2006. ,
Civil structure condition assessment by FE model updating:, Finite Elements in Analysis and Design, vol.37, issue.10, 2001. ,
DOI : 10.1016/S0168-874X(00)00071-8
Time-series methods for fault detection and identification in vibrating structures, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.230, issue.1851, pp.411-448, 2007. ,
DOI : 10.1098/rsta.2006.1929
Statistical time series methods for structural health monitoring In Figure 4 : Indicative damage detection results based on measurements at point Y1 and the: (a) Residual Variance metdod; (b) Residual Likelihood method; (c) Residual Uncorrelatedness method (144 data sets for the healthy state; 144 data sets for each damage state, ?: Healthy state , +: Damage A, * : Damage B ,
Damage E, ?: adjusted threshold; damage is detected if test statistic is over the threshold) ,
A review of structural health monitoring literature, 1996. ,
Vibration based health monitoring for a lightweight truss structure: Experimental assessment of several statistical time series methods, Mechanical Systems and Signal Processing, pp.1977-1997, 2010. ,
DOI : 10.1016/j.ymssp.2010.05.013
Scalar and Vector Time Series Methods for Vibration Based Damage Diagnosis in an Aircraft Scale Skeleton Structure, ASME 2010 10th Biennial Conference on Engineering Systems Design and Analysis, Volume 5, pp.1-22, 2011. ,
DOI : 10.1115/ESDA2010-24275
Statistical moments of autoregressive model residuals for damage localisation, Mechanical Systems and Signal Processing, vol.20, issue.3, pp.627-645, 2006. ,
DOI : 10.1016/j.ymssp.2004.08.005
ARMA modelled time-series classification for structural health monitoring of civil infrastructure, Mechanical Systems and Signal Processing, vol.22, issue.2, pp.295-314, 2008. ,
DOI : 10.1016/j.ymssp.2007.07.003
A model residual based sequential probability ratio test framework for stuctural damage diagnosis, Proceedings of the 5th International Operational Modal Analysis Conference (IOMAC), 2013. ,
Time series-based damage detection and localization algorithm with application to the ASCE benchmark structure, Journal of Sound and Vibration, vol.291, issue.1-2, pp.349-368, 2006. ,
DOI : 10.1016/j.jsv.2005.06.016
Identifying damage locations under ambient vibrations utilizing vector autoregressive models and Mahalanobis distances, Mechanical Systems and Signal Processing, vol.26, pp.254-267, 2012. ,
DOI : 10.1016/j.ymssp.2011.06.009
Garteur group on ground vibration testing. results from the test of a single structure by 12 laboratories in europe, Proceedings of ASME Design Engineering Technical Conferences, 1997. ,
System Identification: Theory for the User, 1999. ,
