Processing of polymer composites: an optical fibre-based sensor system for on-line amine monitoring, Composites Part A: Applied Science and Manufacturing, vol.32, issue.11, pp.1561-1572, 2001. ,
DOI : 10.1016/S1359-835X(01)00003-3
In-situ cure monitoring using optical fibre sensors ? a comparative study, Polym. Test, pp.28-42, 2009. ,
cure monitoring using optical fibre sensors - a comparative study, Smart Materials and Structures, vol.7, issue.4, pp.557-568, 1998. ,
DOI : 10.1088/0964-1726/7/4/017
Vautrin, A Fresnel's reflection optical fiber sensor for thermoset polymer cure monitoring, Polym, Comp, vol.12, issue.4, pp.269-276, 2004. ,
Quatre technologies de CFO pour le suivi de fabrication de matériaux composites, 19èmes Journées Nationales d'Optique Guidée, pp.6-8, 1999. ,
32 km Brillouin loss based distributed temperature sensor, presented at the 9th Opt. Fiber Sens. Conf, 1993. ,
Distributed-temperature sensing using stimulated Brillouin scattering in optical silica fibers, Optics Letters, vol.15, issue.18, pp.1038-1040, 1990. ,
DOI : 10.1364/OL.15.001038
Distributed optical fibre Raman temperature sensor using a semiconductor light source and detector, Electronics Letters, vol.21, issue.13, pp.569-570, 1985. ,
DOI : 10.1049/el:19850402
State-of-strain evaluation with fiber Bragg grating rosettes: application to discrimination between strain and temperature effects in fiber sensors, Applied Optics, vol.36, issue.36, pp.9437-9440, 1997. ,
DOI : 10.1364/AO.36.009437
Discrimination between strain and temperature effects using dual-wavelength fibre grating sensors, Electronics Letters, vol.30, issue.13, pp.13-1085, 1994. ,
DOI : 10.1049/el:19940746
Temperature independent bend measurement using a pi-phase shifted FBG at twice the Bragg wavelength, Fourth European Workshop on Optical Fibre Sensors, p.76530, 2010. ,
DOI : 10.1117/12.866398
Simultaneous measurement of temperature and strain using dual long-period fiber gratings with controlled temperature and strain sensitivities, Optics Express, vol.11, issue.5, pp.476-481, 2003. ,
DOI : 10.1364/OE.11.000476
Structural health monitoring system for aerospace structures using optical fiber distributed sensor, Proc. 3 rd Int. Workshop on Structural Health Monitoring, pp.355-362, 2001. ,
Discriminated measures of strain and temperature in metallic specimen with embedded superimposed long and short fibre Bragg gratings, Measurement Science and Technology, vol.22, issue.1, pp.22-015202, 2011. ,
DOI : 10.1088/0957-0233/22/1/015202
URL : https://hal.archives-ouvertes.fr/hal-00736789
Applications of long-period gratings to single and multi-parameter sensing, Optics Express, vol.4, issue.11, pp.457-466, 1999. ,
DOI : 10.1364/OE.4.000457
Assessment of cure-residual strains through the thickness of carbon???epoxy laminates using FBGs Part II: Technological specimen, Composites Part A: Applied Science and Manufacturing, vol.40, issue.10, pp.40-1534, 2009. ,
DOI : 10.1016/j.compositesa.2009.06.013
Assessment of cure-residual strains through the thickness of carbon-epoxy lami-nates using FBGs Part I: elementary specimen, Comp. Part A: Appl. Sci. Manuf, pp.40-94, 2009. ,
Integrated measurement technique for curing process-dependent mechanical properties of polymeric materials using fibre Bragg grating, Exp. Mech, pp.48-107, 2008. ,
Apparent volumetric shrinkage study of RTM6 resin during the curing process and its effect on the residual stresses in a composite, Polymer Engineering & Science, vol.57, issue.11, pp.346-351, 2012. ,
DOI : 10.1002/pen.22088
